Time Tested Oracle Product Info Solutions: 301 - 322 of 322
hi i am new to oracle i ve downloaded the files disk 1, disk 2 , disk 3 and i tried to install oracle standart edition on a computer running win xp pro with 2.4 ghz cpu and 512 mb ram at ...
there's several times oracle in one of my servers ate all the memory. first I thought it's maybe my code cause the problem, but then i shut down everything, wrote a simple asp page with only ...
hi there, I have a problem  when I try to connect the database from developer 2000, appear an error like this : 'f45des has caused a general protection error in module sql16w95.dll in 000...
Hi all,        Can anyone tell me how to solve oracle Export problem.I have Oracle 9.2.0.4 running on my desktop.When i export my database  it exports tables,views and procedures very fast bu...
Hello Experts, I am a regular viewer of the articles on the site, and recently got a chance to sign up as a user. We have a table which is used to backup the main data, which is a compre...
Hello, I need to use a commercial tool that creates tables in DB. When I checked directly in Oracle the table created I could not  see any contraint on it (via DBA console, No PK, no unique...
Hi and thank you. What is the most efficient way to change a multi-database installation from a standard edition to an enterprise edition, and from an enterprise edition to a standard editi...
I have installed Oracle 8.1.7.0 on AIX 5L but it failed to install lib folder, and keep prompting me error, so i ignored them and let the installation keep going once the installation comp...
Hello I am a Bioinformatist trying to understand the rudiments of Oracle .... I am starting off with installing Oracle on my personal machine (Red Hat Linux).As I am working through the ins...
Can anybody translate the following t-SQL code into PL/SQL code: --CREATE PROCEDURE crosstab DECLARE @select varchar(8000), @sumfunc varchar(100), @sumval varchar(100), @pivot varchar(100...
Oracle 9i using AUM Can anyone tell me the average size of an UNDO tablespace?
hi, is there any way to optimize this oracle update statement. i needed to include the where exists clause so that it wouldn't update the non-matching rows to null. this kind of update happe...
Can someone explain to me what the component "Oracle Windows Interfaces 9.2.0.1.0" does?  I am a training developer and I am currently developing some training based off of the installation pr...
When I try to open Net configuration assistant or Enterprise Manager console I get the follwoing message box --------------------------- jrew.exe - Entry Point Not Found -------------------...
Hi Please tell me the code for outer joining of 2 tables using (+) operator in Oracle. No union or Full outer join keywords are to be used.  i.e implementing Full outer join using (+) i...
ORA-12638: Credential retrieval failed Cause: The authentication service failed to retrieve the credentials of a user. Action: Enable tracing to determine the exact error. how do I s...
I'm trying to install Oracle 8.1.7 Enterprise Edition on my desktop, a Dell OptiPlex GX280 running Windows XP Professional SP 1.  Here's what I've done: 1.  Clicked on setup icon in the bas...
I read the other posts related to setting db_block_size on WnXP Pro, but they don't pertain. I want to make a second database that uses 16K block size. When I use the DB Config Assistant to...
Hi, I'm facing a problem in making reports for Dot Matrix Printers e.g. EPSON. Problem is, I wanna print the report in high speed draft font which is normal a font in any dot matrix printers....
I am trying to connect to another computer with Oracle 10G, via internet. I have defined a local service name, SRM, with the remote IP adress (which is a router/firewall), and port 1521. ...
I accidently truncated a partitioned table using SQLLDR.  How can I get the data back for this table?
I have installed Oracle 9.2.0.1.0 and I cannot log into anything because listener is not active.  I went through the Net Configuration Assistant but still could not get my listener running.
