Anyone having issues with this install....I downloaded OPATCH X.X.X.X.53 and shutdown all servers, stop all services, even turned off any other computers that had access to machine...but when ...
I am currently migrating from Sybase to Oracle 9.2. The process has been 'bumpy' to say the least.
I am attempting to insert values (the result of a two table join) into a table with a u...
i have an oracle 9i and i copied my controlfile to another disk location after shutting down the database and changed my init.ora file to include the control file location. when i started orac...
I get this error with I run a Product Specific Pre-req check:
Problem: The install has detected that the primary IP Address of the system is DHCP-assigned.
Recommendation: Oracle...
