Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested Oracle Product Info Solutions: 76 - 100 of 433
Hi, I am trying to install Oracle9.x Enterprise edition, in "D:\Program Files\Oracle92" directory, with OracleHome name as "OraHome92". I am getting an error "The path you have specified ("D...
How can resolve the following errors: ORA-04068: existing state of packages has been discarded ORA-04064: package body"mv.sbv"has errors ORA-06508: PL/SQL: could not find program unit bei...
How do I call a Stored Procedure / Stored Function and "get the result" in a C program using OCI ? I am looking for a sample program in OCI Release 8. (I am using oracle 9i)
1. Is it possible to have an JSP webpage that show my user last time and date I drop data into a table, and how would I do do the query....I know how to search oracle with a JSP.   2. Then, I...
I have a series of SQL commands for Oracle 9.i.  I need the corresponding set of commands for Oracle 10.1.0.  I believe that dr0csys corresponds to ctxsys.  I have no idea what dr0inst, oractx...
I logon with sqlplus or a third party tools and issue several sql statements. During that session let say my sid=34 and serial#=134. Now I logon as Sys thru sqlplus and want to find all the sq...
Hi, The prompt was this when started imp utility (not impdp): Import: Release 10.1.0.3.0 - Production on Tue Sep 12 18:44:26 2006 Copyright (c) 1982, 2004, Oracle.  All rights reserved. ...
How to check what grants a user has been given in the oracle schema?
Hi, We are having serious issues for our Prod Db 9.2.0.8.0 patch set 13 hosted on windows 2003 sp2 . Total Memory-15 GB SGA-8GB Batches to this server are failing with error ORA-12547: ...
Using the following code: declare v_fac_id number; v_field varchar2(50); v_result number; v_script varchar2(1000); begin v_fac_id := 1; v_field := 'v_fac_id'; . . . end; How c...
Hi everyone, I am tryin to do an import in oracle 8.1.7.4 in the management console and I get the following error: IMP-00058: ORACLE error 12638 encountered ORA-12638: Credential retrie...
Hi, we have here a server: operating system: MS Windows NT Server Oracle 8i Same days ago the network administrator deleted all user-accounts of the operating system and created new ones...
We are trying to use the Oracle SQL Developer software to access an Oracle database. We successfully create a connection to the database, however we couldn't see any table under "Tables" folde...
XA
I have a 9.2.0.4 db server and the users is getting the following error: Please advice in detail. [1/16/04 16:03:34:717 CST] 2f8429b1 WSRdbXaResour E DSRA0304E:  XAException occurred. XA...
I'm setting up in a newly created PC environment.  I'm installing Oracle 9.2i.  When it gets to the phase where it starts up the database I get the error in the title.  I gave it a retry, same...
I have this description of what objec auditing is. However, I still don't understand how it should be implemented or what I should change. Here is a description: Description:  Object auditi...
Dumb question I'm sure.  I am a SQL Server guy trying to learn Oracle.  In SQL server - you can have multiple databases in one instance.  They share tempdb, master, etc.  Can this be done in O...
Greetings, My company just made a big purchase with which included Oracle 10g and performance packages. During their visit to our job site, one of the representative informed me that you do...
I create a user in 10g, release 2 for windows: CREATE USER abc identified by abc default tablespace abc_TS1 TEMPORARY TABLESPACE TEMP QUOTA UNLIMITED ON TEMP QUOTA UNLIMITED ON abc_TS1 A...
I  need to export a schema with all their objects. What command would I issue to do this?
I have 2 Oracle databases running locally on my Windows XP machine, one 9i and one 10g. I just loaded the 10g and I get the error 'ORA-12154: TNS:could not resolve the connect identifier speci...
I am getting this error when I run an asp.net app System.Data.OracleClient requires Oracle client software version 8.1.7 or greater What steps do I need to take to add a reference to the...
I have a text file that is tab delimited that I need to load into an oracle table. The fields are tab delimited. I don't know what the syntax is for indicating in a control file that a field i...
How can I create a datablock in Forms 6i using a stored procedure?
