Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested Oracle Product Info Solutions: 176 - 200 of 433
What exactly is the ALL_OBJECTS.TIMESTAMP Column?  According to the Oracle8i Reference, this character  column is the "Timestamp for the specification of the object (character data)". There...
Hi, Does anybody have any good way ( a script or something like that) to find out the list of one-off patches applied on an Oracle home. No doumentation or backup patch directories are kept u...
Question: I want to run a batch file via plsql trigger I have created it in the database. this batch file is opening an Oracle report. I have found this script to use java class to run the ...
Hi, I have a windoes domain user which was defined on Oracle DB to have access:  DOMAIN_X\USER_Y DB alias = aaprod01 when i'm logined as this user (DOMAIN_X\USER_Y) on the client mechin...
What is the best approach to create a Oracle database using existing datafiles from different server?
Hi, I'd like to do the following: ALTER TABLE local_sale_terms   ADD CONSTRAINT constr_check_cancelled CHECK (NOT EXISTS (SELECT 1                      FROM local_sale_terms         ...
To create additional databases I have used a script file using external commands in Oracle 8.1.7. As such svrmgrl have used to run sql scripts. ie: spool c:\oracle\ora817\admin\MYDIRC\c...
Dear All, I am using the following software and versions. ---------------------------- Report Builder 6.0.8.11.3 ORACLE Server Release 8.0.6.0.0 Oracle Procedure Builder 6.0.8.11.0...
I recently got a new laptop and it is running windows xp sp2.  I installed Oracle 9i and moved everything off my old one to this one.  All settings look identical.  The only difference is the ...
ORA-01631 max # extents (505O reached in table ..xyz Cause: A table tried to extend past MAXEXTENTS. Action: If MAXEXTENTS is less than the system maximum, raise it. Otherwise, you mus...
Is it possible to manually update the Oracle Universal Installer's inventory? I am attempting to apply Critical Patch Update Jan 2005 to a 9iAS Rel1 (1.0.2.2) application server.  The Relea...
Hello, My system is a 9.2.0.1.0 database on Windows/XP.  I imported an schema and after finishing with it I tried to drop the user.  The import came from an 8.1.7.4 system.  I even tried to...
Hi, I'm facing a problem in making reports for Dot Matrix Printers e.g. EPSON. Problem is, I wanna print the report in high speed draft font which is normal a font in any dot matrix printers....
In order to give a middle manager access to the OEM Tool does he have to have the DBA role to sign in to OEM?
I have been noticing this recently in my computer: Eventhough I'm not running any application or program related to ORACLE, oracle.exe gives me high number of memory and virtual memory size. ...
I recently installed the 9.2.0.4 patch on a Oracle 9.2.0.1 database.  When using SQL*Plus, I am now receiving a "SP2-0310: unable to open file "filename"" when trying to access any files forme...
I accidently set a parameter to an invalid directory. I shutdown the database before I realized it. When I tried to start the database again I got an error that the parameter in question has a...
Good Morning,      we are having a problem running the call below: +++++++++++++++++++++++++++++++++++ CREATE  OR REPLACE       AND COMPILE   JAVA SOURCE NAMED "CONCIERGE".""  RESOLVER ...
I have many UNIX servers with many Oracle instances. When a certain application is run on the database server, it creates a deadlock, which in turn hits a nasty Oracle 9.2.3 bug which corrupts...
I'd need to know the Mac Address of the client to keep a record of changes in some tables I chose, since the IP addresses are dynamic and the terminal name can be modified, it seems to me this...
What is the meanning of this error? ORA-00600: internal error code, arguments: [17099], [], [], [], [], [], [], [] Tue Oct 19 14:09:15 2004 found dead shared server 'S000', pid = (10, 1...
Hi, Working Oracle 9 & Linux Red Hat. I cannot access any TEM partitions & the above error are  displayed. At the same time the SYSTEM ROLLBACK statements display a new extension with a ...
We need to install Oracle 10.1.3  Windows 2003. The database data files will reside on an MS1000 SAN Raid 5 disk setup. Our database db block size is 8k. Our db_file_multiblock_read_count is 1...
Hi gang.  I recently installed Oracle 10gR2 on an HP-UX box.  The install seemed to go smoothly.  I started two Oracle instances on a single ORACLE_HOME, and all of my applications are accessi...
Hi Good person, I have an Oracle DB, that's heavily relying on c-shell scripts, and we need to have a DIRECT link between Oracle scripts and the c-shell scripts. In other words, we want to ...
