Hi Experts - I had the PC turned off for a week - came back and had to replace the motherboard 3v Duracell battery as the system was dead. (second time on a 3-year old Dimension 9200)
On re...
I was getting temperature alerts on the temp sensor #2 (CPU) on my ML350 G4 server. I took the heat sink off the CPU and noticed that there was no heat sink compound but there was a square of...
I've just gained a Compaq Proliant DL380 G3 Server for a small office, and allthough its just what we want, the noise the fans generate is immense!, it sounds like ive just parked up a 747 in ...
Hi
I have been brought in an Acer Aspire 5920 laptop for repair with a boot-up problem. When the power adapter is inserted into the machine the blue led near the on/off button comes on togeth...
Hi
I am building a new system in which i m using Intel Q9550 and GA-EP45-UD3P motherboard, 1TB Seagate 7200rpm, 80gb seagate 15000rpm, hp dvd writer, LG LCD 22", 2 GB DDR2 Ram...
Some ...
After the Dell Optiplex GX280 was opened and closed an "Alert CPU fan failure" began to appear at startup. However, the CPU fan is working. Don't know why this message shows up.
Since the fan...
is there a temperature program
computer is
hp dv2700 laptop
These three problems might be inter-related:
!. When I open my MacBook, the desktop icons are sometimes distorted and spread across the screen. I have to go through various efforts to clear i...
Ok Interesting one here
System was all set up and appears to work ok, the network comprises of 4 wireless clients, and 1 'occasionally' hard wired client (laptop). All clients connect to ...
My MOBO has two case fan headers. I want to run three exact same case fans (120mm), all "monitored" not full blast.
Question is:
1. Could/should I run two case fans off of one header using...
My in-laws have a Dell Inspiron 9300 that has worked fine for a few years, but recently the fan runs non-stop (after being off for many hours it starts running the instant the power button is ...
My Pentium 4, 3GHz IBM Think Centre PC with Windows XP Pro will occasioanlly power down without any warning. The power light on the PC remains on but the start button doesn't get a reboot. I h...
I am working on a Dell 4300. It had a case fan that burnt out. So I got a new case fan and hooked it onto the same connection on the board as the burnt out one. Everytime I bootup I get...
I have a Dell Inspiron 5160 that seems to get very hot. what is the max temperature for a computer to be running at. The other day it got so hot it shut down and I had to let it cool off bef...
Are there any half-decent CPU cooling solutions that are passive? E.g. no fan on the cpu's heat sink? Instead, only a single 120mm case fan? I'm trying to build a computer which is exceptional...
I am using APC UPS Smart UPS SURT 10 000XL. I am now looking for Alerting device which will send using Cell phone (not via network exchange -email).
Basically if our server's or air con are d...
Hey Guys,
My computer is over heating lately. It is Sony Viao VGN 2400 series. Basically it came with a fan on the side which had very good vent and never used to overheat ...
Title says it all - running server 2003, need software to monitor tempature and email notifications when server reaches xx degrees.
My motherboard (www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2958) has 3 system, 1 power and 1 North Bridge fan headers, but my 3 case (www.antec.com/Believe_it/pr...
What can I use for an SBS 2003 server to monitor the CPU temperature?
It is a ProLiant ML150 G3 Intel(R) Xeon(R) CPU 5120 @ 1.86GHz
I have a laptop cooler: Beytecc USB cooler.
At what temp. (centigrade) should I haul it out to use to keep the Lenovo SL500 laptop
in WHAT temp. range do you recommend?
Two questions: when...
I have two Dell servers.. A fully loaded PowerEdge 2900 and a PowerEdge SC1430.
They are running Server 2003 and SBS Server 2003.
Anyone know of a utility that will allow me to control the...
We're looking for a product that will track actual power used and overall electrical load by a server room or data center. The closest thing we're seeing to this is APC Capacity Manager. Fro...
