07.01.2007 at 08:25PM PDT, ID: 22669813
Ambient temperature and CPU temp -- how hot is too hot?
Asked by adams_timothy in Computer Fans and Cooling, Hardware Components
Tags: , , , ,
I've got an HP 4400 workstation with two temp sensors -- one reporting 'ambient temp' and another reporting CPU temp.  I  know that temperature monitoring is an important part of computing for gamers, but as for me, I'm a tyro -- I just want to keep the computer cool because I want it to last.  I know that excessive heat is an enemy of electronic components.
The actual temperature in here is about 74 degrees Fahrenheit -- or 23 centigrade.  (Or so says the little thermometer on my desk.)
My readings from the HP 4400 (in centigrade).
Ambient:  36
CPU Temp:  52
(I'm assuming that the ambient reading is taken inside the 4400 box -- if not, I've got a problem.)
How does that stack up? (Bearing in mind that it's summer now, and I compute during the day.)   Perfectly okay, nothiing to worry about, just fine?  Too hot?
I scoured the web, but couldn't find a link to general info on this.  If you have one, I'd love to see it.  Start Free Trial
[+][-]07.01.2007 at 08:37PM PDT, ID: 19400992
Zones: Computer Fans and Cooling, Hardware Components
Tags: ambient, computer, cooling, temp, temperature
Solution Provided By: PUNKY
Participating Experts: 3
Solution Grade: B
[+][-]07.01.2007 at 10:02PM PDT, ID: 19401239
[+][-]07.02.2007 at 01:16AM PDT, ID: 19401901
[+][-]07.04.2007 at 11:52AM PDT, ID: 19420095
[+][-]07.04.2007 at 09:11PM PDT, ID: 19421765
20080716-EE-VQP-32
