07.12.2007 at 04:29AM PDT, ID: 22691327
CPU Fan stops few seconds after starting PC...no display on the monitor
Asked by JatinHemant in Computer Fans and Cooling, Computer CPU Processors, Computer Memory (RAM)
Tags: , , , ,
Hi friends !
In my PC&
1.Harddisk and CD-ROM  are attached to IDE controllers.
2.Floppy drive is connected to Floppy drive controller.
3.RAM is also present and properly fixed in RAM slot.
But when I power on the PC, there is no beep sound. CPU Fan starts and then stops just after a few seconds. (THERE IS NO DISPLAY ON THE SCREEN)  (Because fan rotates for few seconds, I reached on the conclusion that there is no supply problem to fan and also for the motherboard.)
 (MONITOR IS OK, IT IS WORKING WITH OTHER MACHINE)
One by one, I removed signal cables from Harddisk, CD-ROM, Floppy drive and I removed NIC card from PCI slot, Video card also (That connects Monitor to motherboard). But the problem is still there.
BUT WHEN I REMOVED THE RAM, THE FAN WAS ROTATING CONTINUOUSLY.
IS THERE INSUFFICIANT SUPPLY PROBLEM TO MOTHERBOARD ? Has anyone faced the same problem ? Why the cpu fan stops just after few seconds ?
Your help is highly significant&
Hemant
[+][-]07.12.2007 at 04:55AM PDT, ID: 19470668
[+][-]07.12.2007 at 09:33AM PDT, ID: 19473498
[+][-]07.26.2007 at 03:12AM PDT, ID: 19573094
Zones: Computer Fans and Cooling, Computer CPU Processors, Computer Memory (RAM)
Tags: fan, stops, cpu, starts, after
Solution Provided By: palurdo
Participating Experts: 4
Solution Grade: B
[+][-]07.27.2007 at 04:53AM PDT, ID: 19581545
[+][-]08.29.2007 at 04:37PM PDT, ID: 19796338
20080716-EE-VQP-32
