Do not use on any
shared computer
August 29, 2008 08:13pm pdt
Replacing heat sink device at HS2 on Dell computer motherboard
Tags: Desktop PC, Dell Dimension 4600C computer, Dell Dimension 4600C, heat sink is disconnected, Alert: heat sink is disconnected. Shutting down., 2-pin device with loop on top at HS2 is pulled out
My computer was running hot and eventually the error message appeared.  I opened the case and found lint on the heat exchanger beneath the fan and the black-metal, finned heat sink dangling from just loop HS1 on the board.  The pin device at HS2 is missing, pulled from the board as the chip overheated.  I've ordered a new pin device from Dell, but if I need to solder the pin to the bottom of the board there is lots to do to remove the board from the case to access that bottom.  How to re-attach the HS2 pin and loop? and, if the mother board must be removed, how to do that?
Photo of mother board with heat sink and pin and loop at HS2 missing (it's like the one at HS1 to the right)
Question Stats
Zone: Computer Hardware
Question Asked By: Patent_Atty_Chgo
Solution Provided By: rindi
Participating Experts: 3
Translate:
[+][-]Accepted Solution by rindi
Rank: Master
Accepted Solution by rindi:
[+][-]Expert Comment by alikaz3
Expert Comment by alikaz3:
[+][-]Expert Comment by Callandor
Rank: Guru
Expert Comment by Callandor:
[+][-]Expert Comment by rindi
Rank: Master
Expert Comment by rindi:
Rank: Guru
[+][-]Author Comment by Patent_Atty_Chgo
Author Comment by Patent_Atty_Chgo:
Rank: Guru
Rank: Master
20080723-EE-VQP-34 / EE_QW_2_20070628
