put a small blob on the cpu. the cpu is the METAL thing on the chip, it is NOT the whole chip itself. Smudge it a round a bit with your finger. (make sure you wash your finger well some of these products contain things you dont want in your mouth or eye, or even on your skin).
Then take a credit card or something straight. I usually use the packaging the cpu came with the plastic stuff, then smear it very thinly over the cpu. Just enough where you can kinda make out the writing on the cpu die.
The purpose of the compound is to fill in the tiny microscopic fractures that are in the metal. There for making a better heat transfer point to the heat sync. If you goop it on there the metal wont even touch giving you bad heat transfer.
Main Topics
Browse All Topics
by: rindiPosted on 2008-08-23 at 07:46:06ID: 22297217
First very thoroughly clean both the CPU's and the heatsink's surface from any residue of the old thermal transfer paste or thermal pad. Use alcohol to do that. Then, when everything is blank and shiny, apply a very small drop of fresh thermal transfer paste to the CPU's surface, and after that just firmly reattach the heatsink.
