09.04.2008 at 02:30AM PDT, ID: 23701931 | Points: 500
Calibrating / adjusting CPU temperature readings?
Asked by Graphixer in Computer Fans and Cooling, Computer Motherboards, Personal Computers
Tags: ,
Hi gang,
I have an HP Media Center PC with an Asus P5LP-LE motherboard.  I had a power supply fail last week and replaced it.  The machine works fine now, but the CPU and case fans have been going near full speed since the install when they should be fairly quiet.  Both my BIOS and these software monitors (pictured below) are showing my CPU temp going between 72C and 90C depending on load, which seem a bit excessive.
I've reset and updated the BIOS, and reattached the CPU heat sink with new thermal compound but neither helped.  The air coming out the back is cool, as is the heat sink, which makes me think it's a problem with the CPU sensor just wildly exaggerating the actual temp.
Preferring to not simply slow down the fans with SpeedFan, I've searched for a method to either repair or recalibrate the sensor, or dial down the temp readings, but I can't find anything.
Anyone have any ideas before I enter HP support hell?
Thanks!Start Free Trial
Temperature readouts from Hmonitor and SpeedFan
[+][-]09.04.2008 at 03:33PM PDT, ID: 22393395
[+][-]09.04.2008 at 04:33PM PDT, ID: 22393923
[+][-]09.04.2008 at 04:41PM PDT, ID: 22393953
[+][-]09.04.2008 at 05:35PM PDT, ID: 22394221
[+][-]09.04.2008 at 05:36PM PDT, ID: 22394230
[+][-]09.04.2008 at 07:02PM PDT, ID: 22394587
[+][-]09.04.2008 at 10:32PM PDT, ID: 22395508
[+][-]09.08.2008 at 01:48AM PDT, ID: 22415521
[+][-]09.08.2008 at 02:14AM PDT, ID: 22415617
[+][-]09.10.2008 at 01:02PM PDT, ID: 22442382
[+][-]09.10.2008 at 01:22PM PDT, ID: 22442568
[+][-]09.10.2008 at 04:41PM PDT, ID: 22444267
[+][-]09.10.2008 at 05:02PM PDT, ID: 22444393
[+][-]09.11.2008 at 04:04PM PDT, ID: 22455902
[+][-]10.06.2008 at 02:42PM PDT, ID: 22654664
[+][-]11.02.2008 at 01:11PM PST, ID: 22863419
[+][-]11.03.2008 at 09:27AM PST, ID: 22868970
