for now however, you probably could underclock the machine so that it won't produce as much heat (in the bios) and test to see it still overheats.
Main Topics
Browse All TopicsHello
I bought a refurbished DV6131OD (http://h10025.www1.hp.com
Thanks for your help,
Camiille
Thanks for your reply. I would rather not underclock so I don't lose performance. If I clean out the fan and heatsink, do I need to remove the thermal pad before applying AC5? Is it possible for a fan to be "worn out" and rotating at a lower speed than it used it? Is there any way to measure/test this before buying a new fan?
Cheers,
Camille
Business Accounts
Answer for Membership
by: silemonePosted on 2008-10-30 at 13:51:58ID: 22845302
Sounds like you may have to open it up and unstick something or replace the fans...on laptops fans can be easily replaced in most cases.
