CPU Smart Fan control for AMI Bios e8400 ECS G31-TM
Asked by: lexus
In an effort to reduce CPU fan noise in my ECS G31T-M Motherboard (AMI bios v2.59), socket 775 e8400 Intel Core 2 Duo (Not OC), I replaced my very loud Thermaltake with a much quieter Scythe Shuirken SCSK-1000 that supports PWM (Power Width Modulation) adjustable fan speed control.  The mobo has a feature called Smart Fan to adjust the CPU fan speed as necessary, however I do not understand the settings.  When Smart Fan is disabled speedfan registers the fan at 2200 rpm (full speed and a little loud). When Smart Fan is enabled with the default settings, the fan runs at ~300 rpm regardless of the load.  Even with Prime95 running both cores at 100% bringing the cpu temp to 62 degrees doesnt change the fan speed at all. (With the fan at full speed, the temp never reaches above 46)  I want a happy medium.  I have searched all over the net for the descriptions of the Smart Fan settings without success.
Can you please describe (in simple terms) what each of these controls does and what direction change does what:
Smart Fan Start PWM Value      Default 28        (Range 0 to127)
Smart Fan Start Offset (-)      Default 44      (Range 10 to 127)
CPU Delta T            Default +3      (Range 0 to 15)
Fan 1 Slope PWM Value/1Unit I      Default 5      (Range 1 to 15)
Fan 1 Full Speed Offset (-)      Default 23      (Dependant variable)
In a screen before these settings list a dependant variable under PECI Mode called Offset to TCC Activation Temp that is currently -68.
 Thank You.
2009-01-21 at 08:27:43ID24070740
CPU Smart Fan control for AMI Bios e8400 ECS G31-TM thermal cooling heat sink
Computer Fans and Cooling
Computer Motherboards
  1. Fan trouble
    I have a Gigabyte GA-8IHXP(3.0) motherboard with a P4 2.4BGhz CPU. I use the EasyTune utility to monitor my computer's temperature, etc. Well under the Hardware monitor tab, it shows my fan speed, Power1 fan speed and system fan speed. My CPU fan is ok (running at a low 24...
  2. case fans and their usage
    i have 2 12cm fans that i have in the front and back of my case... these fans came from the thermaltake case i use... they are listed to spin at 21dBa at 1400 rpm. however... they spin at 2000 rpm. is this normal>??? i was under the impression that the listed speed was ...
by: lexusPosted on 2009-01-22 at 06:49:41ID: 23439745
I figured out the Main setting: Smart Fan Start PWM Value
It is the starting fan speed.
Value of 0 = slowest fan operates (In my case 300rpm)
Value of 127 = fasted speed of fan (In my case 2200rpm)
For example, if I set it to 60, I get a fan speed of ~1000.
This helps bring the fan to a good all around speed but I have yet to have it ramp up in speed as the temp rises with the increased CPU load.
by: lexusPosted on 2009-01-22 at 12:14:31ID: 23443121
The second setting is solved (sort of) too.  Smart Fan Start Offset (-)
This is the key to the fan ramping up the speed as the CPU heats up.  Although the range of 10-127 is quite large, it is very sensitive to finding the sweet spot.  For example, a value of 70 has the fan running fast (~1500 RPM on my fan) even at start up.  No load or full load has no change for the cpu temp (about 45 degrees) with the fan running that speed.  However a value of 60, and the fan never ramps up from the starting rpm.  ,,,but 66 (on my machine) is optimal.  The fan is on low (500 rpm) until the temp starts approaching 50 degrees, and then the fan slowly increases (often as high as 1200 rpm) to keep the cpu temp below 50-52.  Success!  It is a slow process to adjust this, but once dialed in, should work well.
Delta T and slope probably relate to how fast it reacts as temps rise.  Not sure what change does what, but the settings I have work good now.  Problem solved.
I hope this stays on line to help others with this little addressed issue.
