Which cisco router are you using ?
IOS version ?
Is your cisco router just connected to the virgin modem and serving 4 wireless and one wired client only and nothing else ?
Does your cisco have anyother configuration on it, like a vpn server config or any other ?
to isolate the fault, I would suggest either :
a) Use anyother router (for temp/test purposes) and see if wireless and wired works fine
b) Try to use any other or a new wireless client and see what happens ?
The wireless laptops (their operating system type and version), do they have the latest wireless drivers installed?
I would still suggest to check with any other router (broadband router) and see if everything works
by: tiranathonPosted on 2009-05-18 at 06:50:32ID: 24412002
update : seems i was mistaken, once the 'wired' client is disconnected from the network, none of the 'wireless' clients will obtain a IP from the router.
Error log on the router reveals :
May 18 14:33:26 - unexpected reply: 535 Error: authentication failed
but no idea why, as soon as i connected the wired client back to the router, the wireless clients work correctly again!... strange, anyone have any idea?
