by: CallandorPosted on 2009-09-03 at 13:26:40ID: 25254598
What you saw was probably a thermal pad, as opposed to thermal grease - you don't need thermal grease if you have a thermal pad, but I think metal-to-metal contact with thermal grease filling in the small gaps is a better way to transfer heat.
The thermal sensor is usually on the motherboard below the cpu socket, which is as close as it can get to the actual cpu. It's peculiar that your readings increased and yet the alarm no longer send alerts - did the trigger value get changed?
