Three things...
Did you replace it with an oem fan? I know it sounds stupid, but much of a Dell system is proprietary and any old 12v fan may not work correctly in providing the feedback/sense lines to the system. If it doesn't, you will keep getting the message.
Go to the event log in BIOS and clear the whole thing. You should be able to delete all the events listed.
Lastly, try setting the "Report keyboard failure" to OFF. I know... this makes no sense either, but will sometimes work.
Main Topics
Browse All Topics
by: frostburnPosted on 2009-09-25 at 07:56:46ID: 25423634
Hi there,
If you have gone into the setup and configured the fan settings, try pressing F1 upon boot-up. Go into windows then reboot.
Does it come up with the warning again after that?
Hope this helps
-FB
