Passive CPU Cooling?
Asked by Frosty555 in Computer Fans and Cooling, Computer CPU Processors, Miscellaneous Hardware
Are there any half-decent CPU cooling solutions that are passive? E.g. no fan on the cpu's heat sink? Instead, only a single 120mm case fan? I'm trying to build a computer which is exceptionally quiet.
The CPU is an Intel Quad Core Q6600. The computer won't be used for gaming, just for workstation use. Nothing else inside the case that will generate heat. No overclocking.
[+][-]10/18/09 11:38 PM, ID: 25602957Accepted Solution
Zones: Computer Fans and Cooling, Computer CPU Processors, Miscellaneous Hardware
Solution Provided By: geowrian
Participating Experts: 4
[+][-]10/18/09 11:43 PM, ID: 25602966Assisted Solution
[+][-]10/19/09 12:26 AM, ID: 25603113Assisted Solution
[+][-]10/19/09 06:58 AM, ID: 25605167Assisted Solution
[+][-]10/19/09 08:01 AM, ID: 25605757Assisted Solution
