Do I need extra cooling fan and extra power supply
Asked by: amar31282
Hi
I am building a new system in which i m using Intel Q9550 and  GA-EP45-UD3P motherboard, 1TB Seagate 7200rpm, 80gb seagate 15000rpm, hp dvd writer, LG LCD 22", 2 GB DDR2 Ram...
Some dealers suggested me to use a power supply other than what they have already fitted in the ATX Cabinet and to use a cooling fan(e.g. cooler master) other than the fan which is provided with the processor by Intel.. (they say it increases the performance ): )
Please suggest me in this that do i need to purchase extra cooling fan and power supply or not..
If yes then please refer the brands and power voltage for power supply..
Thanks in advance ,
Amarjit
2009-10-19 at 01:18:39ID24822827
Processor
Power supply
cooling fan
Computer Fans and Cooling
Power Supplies / UPS
Computer CPU Processors
  1. Fans and water cooling
    Hi, just wondering, how many fans are needed to build a computer. Yes, there is the CPU fan, heatsink, etc.., but what is truly necessary? Also, with the water cooling kits such as the AquariusII Liquid Cooling System, is it even necessary to install more fans if I were to ...
by: hatheharikenPosted on 2009-10-19 at 03:51:55ID: 25604030
some extra available power from a custom power supply is definitely good.
if you intend to install a gaming graphics card, a big power supply (in the range of 600-800 watts) is a must.
an extra fan or three, will keep the temperatures down - dramatically increasing the service life of your computer.
also, if your Case / Cabinet has extra fan ports, invest a little in extra fans. they dont cost much.
but they will blow out the host air from inside and keep inside temperatures under control.
Coolermaster, Antec, Thermaltake are very good manufacturers of Power Supplies.
for the Processor Fan - CoolerMaster V8 is showing very good performance on my Core i7 920 - approximately 10-12 Celcius difference from the Stock HSF from Intel.
for case fans - use any 12 volt fan - your local computer store carries Chinese/Korean fans (a few dollars).
but if you invest a little more in a Cooler Master fan - it will last much longer.
by: amar31282Posted on 2009-10-19 at 06:14:05ID: 25604829
Hi hathehariken
I am not going to use any gaming graphic card...
Will i still need a power supply other than the internal provided with Cabinet..
Regards,
amarjit
by: CallandorPosted on 2009-10-19 at 07:21:22ID: 25605358
The Q9550 runs fine with the stock fan if you're not going to overclock it.  If the power supply is not a well-known brand, I would replace it with a solid one from a reputable manufacturer such as PC Power & Cooling, Seasonic, or Antec Earthwatts.  The reason is a cheap power supply may fail at some point, and if it does, it could damage everything connected to it.
by: garycasePosted on 2009-10-19 at 07:47:54ID: 25605608
r.e. the advice to "... use a cooling fan ... other than the fan which is provided with the processor ..."   because "... it increases the performance ..."   ==>  An aftermarket heatsink has NO bearing on performance !!    As Callandor noted, the Intel stock fan is just fine -- it's designed to keep the CPU within its operating range, and does a fine job of doing so.    I generally DO replace it with a higher-end heatsink ... but not because more cooling is needed ==>  I do it purely because I like to build the quietest possible systems; and the Zalman heatsinks that I use are designed with very large fans which can run at lower rpms (and are thus quieter).    They are NOT, however, necessary -- and make NO difference in the functionality of the system.
As for "... Some dealers suggested me to use a power supply other than what they have already fitted in the ATX Cabinet  ..."  ==>  Since you didn't say what power supply is already in the cabinet, or what its specifications are, it's difficult to say whether or not you need to replace it.    I agree, however, with Callandor's comment that you should use a high-quality power supply ==> Seasonic and PC Power & Cooling are the only brands I use for my systems.    For the system you're building, any high-quality PSU of 450w or better would be fine.    Look at the actual supply in the ATX case, however, before you replace it -- it MAY be a reasonable supply.
by: hatheharikenPosted on 2009-10-19 at 09:32:08ID: 25606675
if you are not planning to use gaming graphics, then the stock powersupply is okay.
if you are from india (i am from india too!) - then go for cabinets from color-bit or frontech.
if using cabinet from any other company, i would prefer if your powersupply was at least a Frontech or Atrix
which city are you planning to buy from?
in the indian summers an AC is essential to your PC's health. but if you dont keep your PC in the AC, then you must have at least 1, preferably 2 or 3 fans blowing hot air OUT from the cabinet.
what gary said, see what SMPS you are getting with the cabinet, then decide.
hathehariken.
by: amar31282Posted on 2009-10-20 at 00:26:48ID: 31642794
Thanks a lot guys.. I will go for extra cooling fan and for power supply i will check the default with the ATX if i need new or not...
I am planning to purchase system from Chandigarh.
