You could try speedfan. http://www.almico.com/spee
I wouldn't recommend anything like this though. The best way would be to spare the fans and have your case out with management.
Main Topics
Browse All TopicsI have two Dell servers.. A fully loaded PowerEdge 2900 and a PowerEdge SC1430.
They are running Server 2003 and SBS Server 2003.
Anyone know of a utility that will allow me to control the fan speed, specifically ramp the fans up to maximum? My office is in serious jeopardy of being taken over by the office managers, and I am going to have to squeeze my entire IT office into a very small space. This will mean cramped conditions and separation from the server equipment. I cannot believe this is even being considered!
I would like to make the conditions in this office appear as noisy as possible because I know that is one thing they will not be able to put up with!
Any suggestions? It would have to run from the OS, and not a BIOS thing because I need to randomly alter their speed while running. I tried running processor "burn-in" utilities, but the fans really didn't speed up much. The only time they really ramp up is during the POST at startup. It is quite loud with the sixteen or so combined fans in these rigs!
check this out http://sourceforge.net/pro
From the help guide
"Nothing...
Why?
Lets go back to the configuration dialog and select SPEEDS tab.
We can find an interesting option: AUTOMATICALLY VARIATED. SpeedFan defaults to disabled for safety reasons :-)
All we have to do is enabling this option for both SPEED CPU0 and SPEED CPU1.
Now, back to the main window!
WOW! After less than a minute SpeedFan starts its real job and starts decreasing speeds according to all of our settings!
By default, SpeedFan can set each speed as low as 0% and as high as 100%.
By unchecking AUTOMATIC FAN SPEED, you can stop SpeedFan from automatically selecting speeds for you and you can start exploring :-)
What should you explore? You should carefully listen at your fans (not that difficult, isnt it? :-)) and try to understand which is the lowest speed with an acceptable noise. Some fans are quiet enough even at 50% or so.
After having done some tests, you can go back to the configuration dialog and do the final touch.
One of my fans is quiet enough even at 65%. This is pretty enough as it is still running at 5700 RPM :-) Thanks to this, I set the minimum value to 65%: there is no need for me to go lower as my environment is noisy enough for me to keep the fan running and this will not force SpeedFan to slow down and speed up the fan that often.
My other fan, on the other hand, is a little bit noisier. This is why I set both the minimum and the maximum value for it.
At 90%, the second fan is fast enough to cool the CPU down. At 100%, the noise drawback suggests to use a lower speed :-)
Please, note that if the WARNING temperature is reached, SpeedFan will set fans to 100% no matter what we set here.
What now?
Well... not much. Simply press that OK button and go back to the main window."
Even the help file doesn't work with the servers. I have followed the instructions, and nothing works. The random beep program is pretty cool, and works on my laptop, but the servers apparently don't have internal speakers because that isn't working either. The only thing that kicks the fans in high gear is removing the side of the case while it is running. It is almost deafening when all of the fans kick on!
You could leave it running on your laptop and say that the beeps are monitoring the servers.
Try send off a debug report on the info tab. The programmer who made it might be able to tell you what to do.
Loosen or remove the heat sinks? That should put the fans onto overdrive.
Blocking the fan ventilation should work too.
Business Accounts
Answer for Membership
by: 930913Posted on 2009-11-03 at 13:09:22ID: 25733679
http://www.almico.com/spee dfan439.ex e from http://www.almico.com/spee dfan.php
Don't forget regular random beeps for good measure. Positioning the blinking lights so that they annoy might help too.
