Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested Fans / Cooling Solutions: 1 - 25 of 146
I have HP D530 motherbord when I turn on the computer before booting the error message (512 Chassis fan not detected) appears . I have two fans one for processor and the second for case but t...
I am using an HP Pavillion dv6000 for almost a year and a half.  I use it a lot for playing World of Warcraft.  The Iaptop always used to heat up a lot but still it was working fine until abou...
My computer is self built and comprises an Asus P5N32 SLI SE Deluxe motherboard, Intel core 2 duo E6400 CPU, 2 x Gainward Bliss GeForce 6800 GS "GLH" Golden Sample GPUs, 2GB Crucial Ballistix ...
In an effort to reduce CPU fan noise in my ECS G31T-M Motherboard (AMI bios v2.59), socket 775 e8400 Intel Core 2 Duo (Not OC), I replaced my very loud Thermaltake with a much quieter Scythe S...
I have had my HP Pavillion dv6000 laptop for about a year and a half and for the last 6 months it overheats and shuts down when it is put into "High Performance" mode.  I play some games every...
Hi experts.. was just about getting a dell XPS 1330 when i discovered some issues (http://direct2dell.com/one2one/archive/2008/09/12/nvidia-gpu-update-limited-warranty-enhancement-details.a...
Hi there, I was wondering if somebody would be able to advise me on changing the settings on my HP Pavillion tx1138ea laptop, relating to the extraction fan. Notably, I am currently running...
hi there, I have a 4 year old Sony Vaio laptop. It's a Sony PCG-FRV25 P4 2.66Ghz. When i first bought this thing i could run everything very smoothly, even played WC3 and Jedi knight 2 wit...
Hello I bought a refurbished DV6131OD (http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00782502&dlc=en&lc=en&jumpid=reg_R1002_USEN) and have been using it happily for almost 2 ye...
I have a Dell Optiplex GX280 that is having startup issues. It appears to be a thermal issue as the fan comes on mostly at full speed. It has com on a few times and booted up but then would lo...
Hi There all I have a dell poweredge 2650 server which I use as a homeserver, its great but it does sound like a jet aircraft taking off, I know its a server and noise is not an issue in a ...
Hi Experts - I had the PC turned off for a week - came back and had to replace the motherboard 3v Duracell battery as the system was dead. (second time on a 3-year old Dimension 9200) On re...
Hi, Before I progress I'd just like to say I am an IT consultant with over 12 years of PC building experience and amongst other things assisted Microsoft with troubleshooting WDM driver iss...
The Northbridge fan on my ASUS A8N-SLI motherboard was noisey. ASUS kindly sent me a new fan/heat sink. It appears to install simply by pushing down on two pins which will penetrate the board ...
I have recently bought a second hand HP DL380 G2. When I first bought the machine it had Mandriva on it. When it first boots the machine is quite noisy due to the many fans onboard. After th...
Our company uses several HP 2510p laptops.  These have, so far, been very nice machines with a small footprint.  Only a few of us actually use docking stations with them.  Over the last few we...
I've just gotten a new server (Chenbro RM21508ML chassis w/ Intel S3210SHLC motherboard) and put Fedora 9 on it.  Things are going well so far, except that the case fans run full-tilt 24/7.  I...
My questions is regarding the ideal fan orientation for the Prolimatech Megahalems CPU Cooler. I'm not sure what the best way to arrange the fans and I have the option two use two with this co...
Hi, Does anyone know how to remove the cpu fan from the fan shroud assembly as shown in the photo? The cpu fan is secured by four rubbery towers on four corners of the fan shroud.
I pulled a fan from a raid backplane that I want to replace because it produces too much noise.  The connector is a mini 3 pin connector that none of my in-stock fans have.  I'm trying to trac...
My computer was running hot and eventually the error message appeared.  I opened the case and found lint on the heat exchanger beneath the fan and the black-metal, finned heat sink dangling fr...
Hello, 3 years ago, I bought a new CPU (Pentium 4 2.8ghz) and a new motherboard (Abit IS7). For the first couple of years, this setup turned out to be pretty cool and quiet. According to m...
The fan on my dv9000 laptop is making lots of noise. Research suggests that it may simply be a tag/label that came loose or some other foreign object and all I need is to clean it up. Pressure...
Boought the following computer with this configuration. The CPU fan is shot. The company so far has not responded to my emails given that it has a one year warranty. How much would a CPU ...
I've just gained a Compaq Proliant DL380 G3 Server for a small office, and allthough its just what we want, the noise the fans generate is immense!, it sounds like ive just parked up a 747 in ...
