Time Tested Fans / Cooling Solutions: 26 - 50 of 122
I Need Help: With Intel E660 CPU and ASUS P5N32-SLI SE DELUXE Motherboard. The CPU Temperature is showing at 60c to 70c and the Motherboard from 44c to 48c. I am using Windows Vista Home Pr...
I've just gotten a new server (Chenbro RM21508ML chassis w/ Intel S3210SHLC motherboard) and put Fedora 9 on it.  Things are going well so far, except that the case fans run full-tilt 24/7.  I...
I have had trouble with my Brother-in-laws Computer. It worked fine when I first built it but over time it started locking up randomly often freezing during booting. I though the symtoms seeme...
I understand that stock Intel CPU fans do a good job, my concern is that they are rather loud... Any suggestions?
I own an Alienware Area-51m (laptop) 7700 It is a D900T clevo case with a version 5.3 motherboard. I'm copying a post I've made numerous times describing the issue, as it provides most of ...
Front panel Fan led flashing orange,  When the server fail both led flashing orange Fan and ! When it's fail I reboot the server and get the message "error message: 1611- drive (fan 5) failu...
Hi friends ! In my PC& 1.Harddisk and CD-ROM  are attached to IDE controllers. 2.Floppy drive is connected to Floppy drive controller. 3.RAM is also present and properly fixed in RAM ...
i have a problem with gpu fan settings reverting back to default in nvidia control panel. i play Lord of the Rings online and since their latest update ive been crashing alot. The screen...
I had a PC Chips M811LU motherboard with an AMD Duron 1.8 ghz cpu and recently updated my system. The motherboard/CPU worked fine in my old computer but I recently put it in my dad's computer ...
I just installed Windows XP Pro on a clients machine and it seemed to go well except it seems that the Laptop - Acer Aspire 1300 - fan is on high constantly.  I don't know what is causing this...
Customer phoned - I did work for her a year ago - PC is approx 3 - 6 years old. Error - "CPU fan not connected"   Ive a feeling I wont be able to determine processor type til Im on sit...
Hi,   We are moving to a new building that does not have Air Conditioning in the server room. To put in air conditioning will cost $40,000. We can't use a portable cooler as it's against buid...
I have a Dell Dimension 5150 that is just over a year old. It has a Dual Core Pentium Processor 4Gb RAM and two SATA harddisks. It has a large cooling fan that seems to draw air right through ...
when I boot this HP Proliant pc the CPU fan initially runs very quickly (boosts) then settels down to a normal running speed. after the PC has been used for while (20-30 mins) the CPU fan boos...
Hello, 3 years ago, I bought a new CPU (Pentium 4 2.8ghz) and a new motherboard (Abit IS7). For the first couple of years, this setup turned out to be pretty cool and quiet. According to m...
I recently had to remove a heat sink from a processor to fix an issue with a mounting bracket.  I am now ready to reattach the heat sink over the processor.  Should I reapply thermal compound....
Hello I bought a refurbished DV6131OD (http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00782502&dlc=en&lc=en&jumpid=reg_R1002_USEN) and have been using it happily for almost 2 ye...
I built myself a new PC based on a Gigabyte P35-DS3R and E6750 2GB RAM, 2 X 500GB SATA 2. which is very nice but from time to time it is overheating. I installed Speedfan and at idle it ...
I have a Dell Dimension 8400 that has shut itself down a few times. When starting back up I get a message saying the system was shutdown due to a heat event hit F1 to continue. My power supply...
I am having problems with my HP DV1000 laptop. It was overheating and shutting off, and upon closer inspection I found the fan was not functioning. I dissassembled and found no apparent visa...
i have a computer that sits in a tight spot I need a fan that is quiet that can blow air in the back to help with circulation not a internal fan a external fan
Heat Sink LGA 775 connection to motherboard problem.  I have used the standard stock heatsink / cooling fan that comes with the Pentium D and Core2 Duo 6400.  I have custom built twelve identi...
Hello Experts, I've been having this problem for about a week now. Whenever I boot up my Precision 670, it tells me: Alert! Previous fan failure Alert! Previous thermal failure Alert! Pr...
Hi there, I apologise in advance for what is probably a very simple and well known question, but... In my PC at home there are three cooling fans installed, one at the top, one at the ba...
My Pc has started to make a lot of noise.sounds like a fan ,what is the best thing for me to do to rectify this .and making sure the fan is the problem,whilst i am at it how can I check the PC...
