A friend has an E6300 running on an MSI-V7255 motherboard. He replaced the graphics card with an 8800GTX and changed cases at the same time.
In doing so he broke the CPU cooler and replaced...
Recently installed larger HDD on my desktop Sony RX-550. The Sony System Recovery CD would not allow me to successfully partition/format the larger drive. My research indicates this may be b...
We have a Poweredge 4400 with a flash yellow light for a long time (NOT on the Hard Drive). In addition we have an IBM E server with the same problem. How do I check what this is?
When I bring mt toshiba satillite laptop out of hibernation the fan stays at high speed. I have found what I think might work but havew no idea how to implement the fix. Anybody help me implem...
The backup fan for my Dell Server died on me. I went onto Ebay and purchased a replacement (Dell wanted $120 for one) but upon arrival it is not quite the same. The fan that died was...
Here are the machine specs:
Supermicro P4DCE+
Dual 2.4 Ghz XEON cpus
1.5 GB RDRam
256 mb Nvidia Graphics Card
80 GB SATA HD
CD-rw
3 case fans, 2 cpu fans, 1 PS fan, 1 Ram fan, 1 Graphic...
Hello Folks,
I am having a loud of whirring noise in my computer, after investigating a little this noise is actually coming from the fan. If I stop the fan and start the computer its worki...
I am attempting to install a Socket 939 Zalman 9500 Heatsink/Fan Combo onto a Socket AM2 Mobo. I have the adapter for using a SOcket 939 on a Socket AM2 which can be found here:
http://www....
Ever since I installed a high-availability kit - Intel Management Module, Professional Edition (IMM) and secondary hot-swap power supply and case fans - in my Gateway 9510 Server (aka Intel SC...
I have a Toshiba Satellite A70-S249 that will suddenly power down after it's been on for just a few minutes - when in Windows or when running Hitachi DFT. The first thing I think is overheati...
I'm looking for software that I could use to monitor temperature on servers. I would like to find something where I could have a widget of some kind on my desktop to monitor several serve...
My system (under windows Vista, but it did under XP too) overheats A LOT (talking of temperatures over 80 Celcius in the processor zone), and I would like to take this heat a little dow...
I have an Abit AN7 mb, the nForce2 ultra 400 northbridge chipset heatsink fan went out. I have looked at many different replacements, but don't know what to buy. I want the HSF to have an rp...
My motherboard is very hot and I am looking for any suggestions. Is there such a thing as a motherboard cooling system?
Temperature reads:
CPU 39-41
MOBO 49-51
Asus P5W-DH Deluxe
Pent...
I have an ASUS P4S800D-X motherboard, which is socket 478. I am running a Pentium 4 3ghz w/HT. I would like to replace the cpu fan to obtain cooler temperatures. When I take off the current...
I have an ASUS A8N-SLI Deluxe motherboard that has been working fine for about 1.5 years. Today, when I came into my office my PC had shut down during the night and when I tried to reboot, it...
Hey guys, my gf's laptop started making noises and after inspection it looks to be the CPU fan. I called up a parts vendor for Toshiba and they want 44 bucks for this little thing.. 44 bucks!!...
We recently replaced a Dell Dimension E521 AMD Athlon 64 Motherboard, and after the replacement, the fan is extremely loud - we have done Bios Updates and it is still extremely loud - the reas...
I am working on a clients desktop that is having some heat issues. The customer was stating that it would often freeze and shutdown on its own. I installed MBM5 to monitor the heat. The highes...
I have a brand X box running XP. I am configuring it for my 80 year old father and would like to say,
"When you want to start, move the mouse. When you are done, walk away."
I have my mom's...
need to clean the cpu fan on sony viao notebook (pcg-k315s). How do I access the fan
I have a large podium in my training room with a PC in it. I installed a 120mm AC fan in the side of the podium, but I am trying to figure out how to make it only run while the computer is on...
We recently had the power supply/fan replaced in our desktop tower.
This computer was idle all day, when
we went to use it tonight a distinct hum was coming from the back.
When we checked...
Simply question for those that know the answer.
Are the STOCK Fan/Heatsinks for the AMD X2 5200+ and AMD X2 6400+ the same?
