Time Tested Fans / Cooling Solutions: 76 - 100 of 122
Hi - I need a "how to" - pull apart LG notebook to install CPU fan - any help would be appreciated. Thanks :)
I have a windows xp pro operating system and when I shut down it restarts automatically. I have tried scanning with Spybot 1.6, Adaware 2008 free, Malaware bytes, and Trend micro. All the sc...
Should a cpu fan pull air from the cpu or push the air down onto it, to cool it.
Hello experts, I have a system that reports that the processor fan is not working and turns itself off after 5 seconds. I installed a new fan which also would not run when plugged into main...
I need to compare (Pros & Cons) of liquid cooled systems.  Are liquid cooling systems worth the hassle? Anyone have both sides of the story???
CPU fan stuffed so I replaced it with generic cpu fan. Would not operate. Switched fan into another plug. Fan works ok. But system now closing within 15 secs because cannot detect cpu fan. How...
I have a client with a Linkstation HD-H250LAN that stopped working.  The diagnosis confirms that the fan has stopped working and I need to replace it.  The specs, as sent to me by Buffalo are:...
Where abouts on the laptop does it draw the air in and where does it blow it out?
I have an Acer Travelmate 2423WXCi, just out of warranty (1 year). Over the past few weeks it started slowing down dramatically at various intervals. Certain processes cpu usage would sky-rock...
Are my Laptop P4 3.0 Ghz CPU Temperatures too High. We are dealing with a IBM G40 Laptop that had a new motherboard installed by a non-professional. I may have done a fine job of installing...
I have an ASUS A7J laptop.  It was shipped with an Intel Core Duo processor running at 1.66 GHz, model # T2300.  I've upgraded the processor to a T2600 and now my CPU runs very hot.  It will i...
Hello, Recently I started experiencing some difficulties with my PC. For some reason, while playing CS, I get a hardware hang up. The video suddenly stops, sound jitters for a few seconds ...
I'm trying to learn how to use Speedfan.  I have used UGuru to change fan speeds but UGuru does not seem to change the CPU fan speed anymore. I keep trying to lower the speed as the core temp...
Hi,   We are moving our office to a new location at the end of July. There is currently no air conditioning in the new server room. To install air conditioning will cost $40,000 due to the sp...
Hi Experts, I'm trying to overclock my Pentium D 805 (2.66GHz) on Motherboard Asus P5VDC-X. The Multiplier is 20, default bus speed is 133MHz. I've heard from others that Pentium D 805 is a...
Originally, my system worked perfectly. Maybe a year ago, I noticed that Internet Explorer was malfunctioning.  I tried downloading and reinstalling a new copy, but that didn't help.  So I ...
My server room spent at least 24 hours at 120 degrees plus.  The smell of burnt electronics still looms 24 hours after repair. All systems came back on and are currently running but some st...
i have a 320mm side case fan, yeah i know its a beast and covers almost the entire side casing. i thought it was a cool case, and it does a great job. anyways, the leds on it are pretty annoyi...
hi I ran a program called Speed Fan on an hp desktop computer and all the readings looked ok except for the Core Temperature.It was reading 60c with a little fire icon next to it probably sign...
Good Afternoon, I have spoken with support for the motherboard and Intel...neither of which say there's a problem. My processor keeps going to 100% and the fan speed goes up to 4000RPM...ev...
Hello Need to make a HP DL320S - quieter. so it can be installed in a working office.... on the cheap!!! The fans on this thing our really very loud!!!  Is there any software for makin...
I'm reconfiguring some racks and I'm trying to get the cooling optimal. I can't remember though what the minimum distance you're supposed to have at the back of the racks from the wall is. I k...
Hello guys, I have Dell Inspirion 7500 laptop with W98 which is very old. Suddenly I got a black screen w/operating system not found. When I rebooted it's making a loud buzzing sound and at...
Hi, My ECS PF5 Extreme motherboard's chipset fan has developed a really annoying squeal. I guess the easiest way to correct it is to disconnect it. Has anyone else done this? Am I going to ...
The fan on my computer seems louder than it's suppose to.  It's seems as if it's working too hard.  What could the problem be?
