Hey...i am trying to replace my Heatsink fan attached to my motherboard on my PC. The fan in there now is the wrong one (its just a fan no heatsink attached) i am trying to find the right heat...
I have a dell XPS Gen 3 and in the bios settings there is nowhere that i can see to disable the fan monitoring. I replaced the rear fan and cpu fan and now it pauses to alert me every time i ...
I happened to be inside my system yesterday and noticed I have several (like nearly a half dozen) of the capacitors that have burst.
System seems to be running fine - although apparently ther...
Hello Experts:
My new P4 3.4Ghz CPU Overheats, and it is not overclocked
This Vista Ultimate clone has:
" A new Gigabyte S-Series Motherboard model: N850SLI-DS4
" A new Radeon HD 2600 P...
I need a noise-less alternative to my recent noisy Video Card Fan.
It is an ASUS AX550 as it is at the following link : http://www.asus.com/products.aspx?l1=2&l2=8&l3=201&model=554&modelmen...
Im not at the machine now, but have to get a new heat sink / fan for it tomorrow.
Is it enough to say pentium 4?
http://support.asus.com/download/download.aspx?SLanguage=en-us
Mother...
CPU fan sounds like a jet engine... LOUD. I built a chasis 1550 (intel) and the 5000pal board with a intel 3.2 ghz 5060 cpu. Built it from scratch and got it up first time. Only issue is th...
We sell quite a few Shuttle water-cooled SFF base units.
A client wants to stack 2 DVD drives so we cannot offer this SHuttle as it only has one bay.
Is it possible to use water cooling i...
I have a acer desktop system which is shutting down because the CPU is overheating - I originally thought the fan was not working so I replaced it - the new one worked for a while and now it a...
Hi all,
I have an Intel Server with the motherboard SE7501WV2.
I REALLY need to monitor the CPU / Fan etc temperatures.
I've tried Motherboard Monitor but can't seem to get it up and ...
i have a liquid cooled Kandalf LCS case, my computer will turn on for a second and then turn off i believe my processor is damaged i noticed that the cpu water block is draining out faster the...
I have an older ABIT KG7-R motherboard with an XP2800 AMD Socket [A] 462 proc.
Last fall, I was cleaning the CPU fan with a can of air while the computer was running. That was my first mist...
Once in a while when my Dell Dimension 2400 desktop computer has been running for a while, I will hear the power supply fan stop and then start. On rare occasions, the computer will restart ...
1. Will an AMD64 3800x2, Socket 939 CPU work with a new, but never used Plain Amd 64 Socket 754 HSF?
It appears to fit perfectly in the retention bracket of a new MSI 939 Mobo, but...
The case is here:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1901960&CatId=1842
So I would use the 250 side fan and a 120 in front and a 120 in back for ...
I have an Alienware Laptop - it sits on a cooling plate already - no the bios is not overclocked.
This thing will cook a seven course meal. When it reaches a certain temp it will shut down.
can you use a 478 heat sinck and fan on intel socket 775
my cpu fan will turn off as soon as computer try to go to OS, even in safe mode. I have checked the power supply and the BIOS setting ,everything seems in order . I'm lost!
Hi all,
I have a main board right on my desk (with no housing). The pc cooling fan looks similar to http://images.tigerdirect.com/skuimages/large/S457-1017-a-wg.jpg and is too loud. So I wa...
Hi to all!
I have a case by supermicro, its model number is SC512L260B.
I think this can be a link of the product: http://www.supermicro.com/products/chassis/1U/512/SC512L-260-LCD.cfm
t...
We have a brand new Apple Xserve purchased in May 2008. It is 2x2.8GHz Quad core CPU, 3x73GB SAS HDD with RAID.
It the last 2 weeks it was crashing every alternate days. Each time I run a ...
I Have a problem when I try to turn on my computer you see the led light that indicate that power is going to the computer but the computer monitor is off but the fan to the processer is blowi...
why is my dell latitude d630 running so hot
