I have a Dell Poweredge 2650 that recently began rebooting itself every approx. 24 hours. Upon reboot, it displays "embedded server management error" and then sticks at the prompt for F1 to c...
I've one OPTIPLEX GX520, when I press the power button I just see one static amber light, and I don't receive nothing of video signal.
Can some body tell me or suggest som...
Does anybody have step by step instructions to get the APC PCNS agent for Linux to successfully install on the latest flavor of Ubuntu? The install succeeds but the required ./PCNSconfig.sh s...
Help! I can't turn on my Dell Latitude D410. When I press the power button, the 3 green lights come on for a few seconds, but then they go off again. I've tried it with and without the dock...
I recently bought a 'Belkin AC Anywhere' DC to AC inverter for my car. The main purpose of it is to run/charge my laptop on the move. On the product, the output is mentioned as 240 Volts and 2...
I have 2 DELL Servers PE2800 and PE2950, both connected to an APC UPS. When the power cuts, the APC UPS Network Mgmt Card is configured to shutdown the servers. I want to have the servers star...
Well my computer crashed last night, I'm not sure if it overheated or what happened but I had it plugged into a power strip and when I tried to turn it on in the morning with the external powe...
How to make a sinus inverter with input 12 volt accu NS-100 and the output 2200W AC?
Any body had the electronic circuit schema ?
All i did was swap a harddrive to install xp on it.
Then i swapped back to my old one
ever since then the fan has been running louder and it comes up with a BIOS prompt that says Powerfan is...
We have about 100 users that need to use their personal laptops for extended periods of time - 2 x 3hr session 1hr apart is the worst case scenario. We have asked them to bring 2nd/e...
I have two APC Smart-UPS 1500s (DLA1500RM2U). When I plug them into the wall, about once every second they emit a beep and blink most of all of the LED indicators on the front. Actually the ...
Hello, I have 3 servers running Server 2003 all connected to a APC2200 rackmount UPS with a 9618 Environmental card. I can do it with one server, but how do I configure all 3 servers each with...
I have been given a Toshiba laptop to look at that will not power up.
When the laptop is plugged in to the power with the battery installed and the power button pressed the battery LED flashe...
I have to bulk up our ups setup. What would you suggest for the following server room? What do I need to consider. I would like them to be able to do a manual shut down in the event of a po...
I'm working on a PC build and everything is working, except I can't get a cable that's long enough to reach from the front buttons to the motherboard. Does anyone know where I can get a power...
Custom built machine with 550 W PS likely hit by power spike. Nothing happens when power button pushed. No light lights on the MoBo when plugged iin. Connected (without actually installing,...
I have 2 Dell Poweredge servers (windows 2003) that i want to set their power on time delay to 5 minutes or so, after the power returns. This is to give time to the 2 Domain Controllers...
I have six switches in a small data "closet" with no enviornmentals so temprature can be an issue. What is the best APC UPS unit that can provide enough power and runtime (~20 minutes) for si...
I have a whitebox 4U rack server with a Xeon 2.8 (single CPU on dual-capable Intel board) with a 6x 10k SCSI array. The power supply is non-redundant 600 watts. We need to add an additional ...
I am building a media center and I recently got all the parts that I needed. So I got all the parts put together and I was putting in an old power supply I had from another computer when I rea...
I have a APC UPS. It keeps buzzing or beeping, until I turn it off, starts buzzing again when I turn power back on. Do I need a new battery or ...?
I have 2 DC (windows 2003), each on a DELL Optiplex 755. When the power cuts, the APC UPS Network Mgmt Card is configured to shutdown the DCs. When the power comes back, the DCs auto...
I have a MSI/IBM server computer that has run fine with windows xp installed. It has now started to turn the video off-- now I turns the video off before windows xp can finish loading. In f...
Craziest title I've ever written. :)
hopefully some electronics guru out there can answer this for me.
Every Fall and Spring I see a handfull of computers that will not power up. No respo...
I ordered a charger for my HP Pavilion PC and it did not come with the cable that plugs into the brick and the outlet. Just the brick and the cable that plugs into the laptop was shipped.
S...
