UPS battery lights flashing
Asked by: wunderlich
I have a APC Smart UPS 2200. All five of the "battery" lights are constantly flashing. I read some things on the net about it and all they say is to replace the batteries. I replaced the batteries on Friday afternoon to hopefully resolve this issue, but even with the new batteries the same issue is still present. I tried to get a hold of APC, but I sat on hold for 30 minutes to no avail so I hung up. Does anyone have any information that could assist?
2007-10-01 at 09:39:52ID22864127
lights
flashing
apc
battery
ups
Power Supplies / UPS
  1. APC battery
    I have several APC UPS, some of which don't seem to work anymore, I assume the battery needs to be replaced. Is it a standard thing to buy replacement batteries for these APC or to buy a new APC? thanks Ptran2000
  2. APC UPS - Flashing Battery meter
    I have a SU1400NET UPS unit by APC which has a problem. The battery meter starts flashing anytime I get the unit over 50% load. I just put in new batteries today to try and solve the problem and it still flashes the battery meter anytime the load is above 50%. The describe...
  3. Silence the Replace Battery 'Beep' on an APC SmartUPS
    I have a (5 year old) APC Smart UPS 1000 with a dead battery. I am going to replace it on the weekend. In the meantime, is there a way to silence the 'beep' (telling me that I have a dead battery)?
  4. APC UPS battery charge
    I have bought APC BE400-GR UPS (400VA 240W) . I need answers to the following questions: 1) Is the battery fully charged when it is new? 2) Do I need to charge it when I plug it in for the first time, and if yes, do I have to charge it without any devices plugged in, or I am...
  5. APC Battery Replacement & Charging
    Hi, Probably an easy question for someone to answer . . I have got to a situation where I need to replace the battery in my APC UPS and I just need some simple advice. I know from reading the instructions that the battery is hot swapable, but in this particular instance I ...
  6. APC UPS battery issue
    Hi Experts I am attaching one picture of APC ups. The lite above battery with X sign is red now is it means it is time to change battery?? The battery sign in right hand with 5 green lights are normal.
by: wunderlichPosted on 2007-10-01 at 12:15:30ID: 19993259
I will try this out this afternoon since I currently do have a critical load on it. I will get back to you on this tomorrow and post Points. Thanks.
by: wunderlichPosted on 2007-10-09 at 10:05:24ID: 20042551
APC is sending a device to us to fix the issue. I appreciate the assistance.
by: souseranPosted on 2007-10-09 at 10:09:03ID: 20042582
Glad to help. Thanks for the points.
