Silence the Replace Battery 'Beep' on an APC SmartUPS
Asked by: tnorman
I have a (5 year old) APC Smart UPS 1000 with a dead battery.  I am going to replace it on the weekend.  In the meantime, is there a way to silence the 'beep' (telling me that I have a dead battery)?
2008-03-18 at 09:04:38ID23250642
Power Supplies / UPS
  1. Beeping
    I keep hearing a single beep at short regular intervals and it appears to be coming from my speaker area, but when I turn the volume up or down it doesn't affect the loudness of the beeping. What can I do to make it stop?
  2. APC battery
    I have several APC UPS, some of which don't seem to work anymore, I assume the battery needs to be replaced. Is it a standard thing to buy replacement batteries for these APC or to buy a new APC? thanks Ptran2000
  3. Conext 900 AVR UPS Battery beeps and restarts the sys…
    Does anyone have the computer reboot problem with Conext 900 AvR UPS Battery? I have two dell dimensions connected to one UPS..The systems work fine, but the computers shuts down after a click noise in the Battery backup..This happens randomly and I dont know what is causing ...
  4. UPS beeping and battery end-of-life ?
    Hi, One of the users in a remote country tells me that their UPS (SmartUPS 700) is beeping once in every +/- 3 houres and there is red light burning that indicates that the battery should be replaced. The battery also indicates that it's fully recharged? What seems strange ...
  5. UPS still beeping after battery replaced.
    Our APC Smart UPS 1500 was beeping for a minute every 5 hours and the replace battery light was on. I removed the old battery and replaced with a new one but the red light is still on and it has since beeped again. Do I need to give it more time or could there be another pro...
by: garycasePosted on 2008-03-18 at 10:12:10ID: 21153353
According to the APC knowledgebase, the alarm cannot be silenced.   It should, however, only occur for one minute every five hours.    The only way to silence it is to replace the battery :-)
This is from the knowledgebase for the Smart UPS 1000:
3. UPS has failed the battery self-test - unit will beep continuously for 1 minute, every 5 hours, and the red "replace-battery" LED will be illuminated, until the condition is cleared.
Note: This alarm cannot de disabled.
