No and I won't be.
Main Topics
Browse All TopicsI have a Smart UPS 1500 with 1 file server running Windows 2003R2 and 1 Xp Pro Workstation. I can see and manage my file server just fine but I cannot add the XP Machine to the device list. When I try by either machine name and or IP address I receive a message "Failed to add 192.168.1.15". That's it.
I must be missing something here. My server is running PowerChute Business Edition 7.0.4, build 114
and is connected via USB. The only link between my XP machine and the UPS is the power cable itself. I would have assumed I could find the box on the network and add it to the list. Do I need a cable or agent or something?
I have the same problem with a Smart UPS 1000 with two Windows 2003 R2 servers - I can only see the one that has the direct USB aconnection.
Guidance in resolving this would be great.
You need an agent on the remote systems. Powerchute has remote agents that you can install and link these back to the management console....alternatively, as they are HP UPS's why don't you install HP Power Manager 4.2.7 on the servers physically attached to the UPS's and then download and install the Power Manager remote agent and install on the other systems....these will report back to power manager. Note that you may have to open firewall ports in XP for these agents.
Business Accounts
Answer for Membership
by: aleghartPosted on 2008-11-25 at 13:19:17ID: 23037804
Do you have the network card installed on the UPS?
ts/family/ index.cfm? id=98
http://www.apcc.com/produc
