| Search, ask, and monitor your questions on the go with EE Mobile. Visit Experts Exchange from your mobile device and never be out of touch again. |
| With so many solutions, how can you tell which solutions are most likely to help you and which ones are not? To provide you with a tool to use, we rate our solutions based on various elements that most accurately determine if a solution is a quality solution. To explain what factors affect the solution rating, here are the elements we take into consideration when formulating our solution rating. - The Grade of the Solution
- The Zone Rank of the Expert Providing the Solution
- The Number of Author and Expert Comments
- The Number of Experts Contributing
- The Feedback of the Community
Your Input Matters Because of the way the system is set up, the most important variable in this equation is you. As a member of Experts Exchange, you are able to cast your vote on the quality of the solutions in regard to how complete, accurate, helpful and easy to understand each solution is. When you provide your feedback, each rating is adjusted accordingly. So, if you see a solution that has a poor rating that you think is a good solution, let us know by rating it. As you do, the rating will be adjusted and will become more accurate for other members of our site. If you have any suggestions that you would like to make for our rating system, please ask a question in the Suggestions Zone of Community Support. Thank you! |
Asked by supportoranges in Power Supplies / UPS, General Laptop, PC Laptops
I'm going to do a laptop keyboard replacement on-site at an old residence and I'd like to follow ESD procedures.
I have two choices, ,attach wrist strap to chassis of non-plugged in laptop or (preferably attach anti-static mat to ground and the wrist strap to the mat).
In many homes, the receptacle covers are painted or papered so that simply grounding to the screw of the receptacle faceplate may not work.
I have no idea where else or how I could attach an anti-static mat to ground it at unknown offsite location.
Ideas? (It seems the only way to attach the mat is by screwing the anti-static mat's conductor onto something)
20091021-EE-VQP-81 - Hierarchy / EE_QW_2_20070628
