Calculate BTUs?
Asked by mgcIT in Power Supplies / UPS, Miscellaneous Hardware, Computer Fans and Cooling
Tags: APC, UPS, BTU, Watt
My APC battery system shows the following information.  How do I calculate how many Watts (and therefore BTUs) I'm currently using?
      Utility power status
 Input Voltage:        210.2        VAC
 Input Frequency:        59.99        Hz
 Maximum Line Voltage:        210.2        VAC
 Minimum Line Voltage:        203.0        VAC
      Output power status
 Output Voltage:        208.2        VAC
 Output Frequency:        59.98        Hz
 Load Power:        072.0        % Watts
 Apparent Load Power:        058.0        % VA
 Load Current:        28.14        Amps
Keywords: Calculate BTUs?
[+][-]03/30/09 04:49 PM, ID: 24024574Assisted Solution
[+][-]03/30/09 09:09 PM, ID: 24025660Expert Comment
[+][-]03/31/09 09:23 AM, ID: 24030617Author Comment
[+][-]04/01/09 11:32 AM, ID: 24042205Expert Comment
[+][-]04/02/09 04:20 AM, ID: 24048454Accepted Solution
Zones: Power Supplies / UPS, Miscellaneous Hardware, Computer Fans and Cooling
Solution Provided By: PCBONEZ
Participating Experts: 3
[+][-]04/02/09 04:32 AM, ID: 24048517Expert Comment
[+][-]04/08/09 02:30 PM, ID: 24102059Author Comment
[+][-]04/08/09 03:08 PM, ID: 24102418Expert Comment
[+][-]04/08/09 08:12 PM, ID: 24103789Expert Comment
[+][-]04/09/09 01:11 AM, ID: 24105068Expert Comment
