Graceful Shutdown without Powerchutes
Asked by Djrobluv in Power Supplies / UPS
We have 3 small servers plugged into a APC Smart-UPS 750XL with a battery pack attachment. Problem is we can only connect, technically 2 systems to the UPS via serial cable and USB cable. Serial cable only works 50% of the time. Is there a way I can make the 3rd server gracefully shutdown when the battery power is low without using powerchutes software? I know there is a Network Card we can purchase to install in the smart slot on the UPS. But due to hard economic times, I was told to search for a alternative solution first.
[+][-]05/12/09 09:22 AM, ID: 24366342Accepted Solution
Zone: Power Supplies / UPS
Solution Provided By: 3nerds
Solution Grade: B
[+][-]05/06/09 08:49 AM, ID: 24316263Expert Comment
