Embedded server management error
Asked by: fabiouness
I have a Dell Poweredge 2650 that recently began rebooting itself every approx. 24 hours.  Upon reboot, it displays "embedded server management error" and then sticks at the prompt for F1 to continue, etc...I talked to Dell tech support and this is what we tried: downloaded ESM Firmware flash utility, tried it and got a message saying that it's incompatible with the current configuration, reset the NVRAM on the motherboard to take the ESM back to original, tried the flash utility again and got the same incompatibility message.  He said at this point that I need to replace the motherboard.  They want $606 for it, so I want to confirm that this is my only option at this point before I go through with it.  Also, is the server going to keep rebooting at around this 24 hour interval until something else is done?  Is it going to reboot with increased frequency?  Die eventually?  Thanks in advance.
2009-06-04 at 16:36:05ID24465590
Dell Poweredge 2650
Power Supplies / UPS
Computer Servers
  1. Manage Exchange 2007 with Exchange 2003 ESM
    I have a mixed environment of exchange 2003 and exchange 2007. I am trying to manage my exchange 2007 through the ESM of exchange 2003. When I expand servers and am able to see the servers of 2003 and 2007 version of exchange, am also able to see the mailbox of users when exp...
  2. Computer Began Fluttering and Does Nothing Else
    This morning while my wife was working in Word (doing nothing unusual) her computer began making this fluttering (she calls it clicking) sound and the screen went blank. When it's turned off and back on it does the same thing and nothing else. The drive light is on solid. ...
  3. Poweredge 1650 Motherboard
    I have a PowerEdge 1650 that I have recently replaced the motherboard and ROMB card. The system will power on, fans/lights but the hard drives do not spin up nor will the BIOS start. I know I am over looking something but can't seem to see what I am missing.
  4. ESM on Vista
    I'm running ESM on Vista and noticed a slight problem. IN ADUC the exchange features tab is blank and has not values for any uder in my organization. Why would this be and how can I get this tab to poulate with data?
by: 65tdPosted on 2009-06-04 at 17:40:35ID: 24552682
Any in the windows event logs (if running windows)?
Is Dell OpenManage software running this box?
OpenMange software:
http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=2331&libid=36&releaseid=R198997&vercnt=20&formatcnt=0&SystemID=PWE_FOS_XEO_2650&servicetag=&os=WNET&osl=en&catid=-1&impid=-1
Driver and firmware link Dell:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&&os=LHS64&osl=en&catid=-1&impid=-1&SystemID=PWE_FOS_XEO_2650
Depending on the issue - power supplies, board fault it could increase and it will eventually die.
by: fabiounessPosted on 2009-06-04 at 19:53:40ID: 24553146
Nothing seemingly critical in the event logs related to this issue (running Windows Server 2003).  Running OpenManage software 5.5.0 and, checking the logs, got two 2145 ID warnings today around the time I was working with Dell support.  They also appear in the event log of Windows, though.  That ID states low battery on the Perc controller (Perc3/Di), but from another post on EE, it says that a Poweredge 2650 is a model that doesn't require the battery to be reconditioned.  Could this be the cause of the embedded error, or at least related?
by: fabiounessPosted on 2009-09-03 at 18:43:33ID: 31589051
Issue was determined by Dell tech that embedded server software was corrupt or broken and can't be fixed.  Motherboard had to be replaced.
