Dell Latitude D410 Won't Power Up and Stay On
Asked by: chsccg
Help!  I can't turn on my Dell Latitude D410.  When I press the power button, the 3 green lights come on for a few seconds, but then they go off again.  I've tried it with and without the docking station and with and without the battery.  If I hold the Function key while I power up, the "arrow lock" light (on the right) stays on for a few seconds before it turns off.  I think it's a bad motherboard, but I'm hoping it's something easier to fix.  (This all began when I made the mistake of removing it from the dock without powering down.  It worked fine while it was out, but when I tried to redock, it turned off.  And then I couldn't turn it back on.)  It seems to be a power issue (motherboard-related?) as far as I can tell; I think the rest of the hardware is OK.  Can you confirm whether that sounds like the motherboard or something simpler?  If it is the motherboard, is it worth fixing?  (It's several years old.)  Please let me know if you need more info about what happened or what I've tried.  Thank you!
2009-08-28 at 03:52:48ID24689359
Dell Latitude D410
power
Power Supplies / UPS
PC Laptops
Miscellaneous Hardware
  1. Dell Latitude power problem
    Ive got a Dell Latitude Laptop that will not power up even with the power cord hooked up.Theres a little battery light on the side that blinking red and green.Any help would be much appreciated
  2. Dell Latitude D600 Docking station Problems
    Hello, I have a Dell Latitude D600 notebook and I currently have 3 exact docking stations for it. When I connect my notebook to any of the 3 docking stations it will not Detect any USB devices. I have reinstalled the drivers for it and it still dose not work. Any Ideas?
  3. CMOS battery on laptop. Dell D820 Latitude
    CMOS battery on laptop. Dell D820 Latitude. Cant seem to find it. I took the top keyboard off. Do you think the battery is located further inside the laptop. I need to take the battery out to clear the BIOS password. Thank you.
  4. Dell Latitude D520 battery not recognised
    Suddenly my Dell Latitude 520 has stopped recognising the battery. The battery is still working, I can charge it and run the laptop using it. There are no error indicator lights on the battery but when I look in Power Options the power meter states no battery is installed. ...
by: tim1731Posted on 2009-08-28 at 04:38:55ID: 25206498
Try taking out the battery and power and holding down the power button to drain any remaing power (10- 15 secs) battery back in and power on
by: PhilonatorPosted on 2009-08-28 at 06:33:04ID: 25207435
Couple thoughts-
It does sound like the motherboard went bad when you did this.  Since you were docking/undocking when this happend flip over the laptop and see if there are any bent pins or if there is a foreign object in the docking port hole.
to the other experts- is there a way to reset the pram on a dell?  On compaq, it was hold the c key or something screwy like that.
by: chsccgPosted on 2009-08-28 at 08:04:09ID: 25208411
@tim1731 - I already tried that and it didn't work.
@Philonator - I just checked and didn't see any bent pins or foreign objects in the docking port area.  I'm intrigued by the idea of resetting the PRAM with keystrokes, though....
by: tim1731Posted on 2009-08-28 at 08:11:32ID: 25208489
try booting,
1.without the battery
2.With 1 stick memory swap them out one at a time
3.remove any pcicma or sd cards
by: chsccgPosted on 2009-08-28 at 08:27:59ID: 25208669
@tim1731 -- I already tried booting without the battery, memory, and cards.  I also removed the keyboard, modem, and hard drive for good measure.  It did exactly the same thing -- lights on for a few seconds (with faint start-up whir) and then dead again.
by: PhilonatorPosted on 2009-08-28 at 08:48:19ID: 25208879
pram is the was the wrong word,
I think i know what your problem is but, I can't find the solution even in a google search.  Call dell and they will have you remove the battery from the machine then boot it while holding a combination of key(s) on ac power.  These keystrokes are not the normal ones like f12, f8, etc.  Get your express service code before you call.
by: chsccgPosted on 2009-08-28 at 08:54:25ID: 25208929
@Philonator - Unfortunately, it's no longer under warranty, so I don't think I can call Dell.  They did help me a bit via text/chat support, but they just said it was the motherboard without much further explanation.  They didn't mention any keystrokes to try.  The only thing I've found reference to is holding down the Function key while powering up to show the error codes (arrow-lock key).  The Dell person said that was consistent with a bad motherboard, though only after *I* raised the issue.
by: PhilonatorPosted on 2009-08-31 at 05:20:44ID: 25222160
Even if it is out of warranty they will still help you with phone support, just if a piece of hardware is bad they will sell it to you instead of cover it under warranty.  I am going to try another google scour for you.
by: chsccgPosted on 2009-09-04 at 09:43:56ID: 25261287
@Philonator - Did you find anything new in your web search?  Thanks!
by: chsccgPosted on 2009-09-15 at 14:32:33ID: 31621645
It does appear that the motherboard went bad.  I guess the only solution is to replace it.  I didn't get any keystrokes that worked to reset things, so we're going ahead with replacing the motherboard.
