It's kind of difficult to answer this question, since the input current isn't specified, nor the output voltage - in general, you can't output more power than you put in. If you really want to output 2200 watts @ 120v, that's a huge amount of power and should be done by a qualified electrician or you should use a commercial product, as that can easily cause a fire or kill someone if done improperly.
Main Topics
Browse All Topics
by: d-glitchPosted on 2009-09-10 at 11:58:20ID: 25303179
Specifications for an inverter include:
/id/2/type .asp
Input voltage: 12 VDC
Output voltage: 120 or 220 VAC
Output Power: 2200 Watts
Output Frequency: 50 or 60 Hz
Check the commercially available products before you try building one of your own.
Inverters can generate deadly voltages.
Xantrex has a very good line:
http://www.xantrex.com/web
