HP Proliant ML310 G5 Power Supply Replacement
Asked by: NCTERW
Can the power supply in an HP Proliant ML310 G5 be replaced with a standard desktop power supply? The HP replacement power supplies I have found are in the $200 range and money tight right now. Thanks for your help!
2009-11-05 at 14:06:05ID24876281
Power Supplies / UPS
Computer Servers
  1. Can NT4/SQL7 run in HP Proliant DL 380 G5 box?
    Hi, I check with HP and unfortunately the box does not support NT4. If possible, I may still need to reinstall NT4/SQL7 in some newer hardware (than currently running). One option is HP Proliant DL380 G5, but not sure what problems I may end up with NT4/SQL7. Can someone prov...
  2. Driver for the HP ProLiant ML110 G5 Smart Array SATA …
    Does anyone knows where I can find the driver for the HP ProLiant ML110 G5 Smart Array SATA Controller for Windows 7 ?
  3. Setting up HP PROLIANT DL185 G5 RAID configuration
    Hi Everyone, How do you get to the RAID configuration utility for HP's Proliant DL185 G5 machines? I didn't get a SmartStart CD with the server, are those still required? Thanks, Theodosios
  4. HP ProLiant ML110 G5 Network Card
    Dear All, I have a HP ProLiant ML110 G5, and I want to add an extra network card for it, unfortunately the HP compatiable NIC is a bit expensive, can I buy any NIC from the local market , or I need to look for certain specifications? My OS is Debian Lenny.
  5. HP Proliant ML310 G5 Drive Upgrade
    My Client is looking to upgrade the Hard Drives in their HP Proliant ML310 G5 Server running SBS2003. Currently they have (3) 146GB SAS drives running RAID 5. They want to go to (4) 300GB SAS drives running RAID 5. Now I'm more familiar with Dell PE servers. Dell has the Dell...
  6. HP proliant DL380 G5 ESxi install
    I am attempting to install the free version of VMware (ESXi?) on a HP proliant DL380 G5, Is this hardware compatible with this free version of VMWARE?
by: tigin44Posted on 2009-11-05 at 14:12:43ID: 25754630
For me do not  try that. Its original power supply has the PFC property and as I remember it also has hot plug property too.. Usually the pc power supplies do not have these  properties.
by: NCTERWPosted on 2009-11-05 at 14:20:41ID: 25754722
This particular server does not have a hot plug power supply.
by: tigin44Posted on 2009-11-05 at 14:29:07ID: 25754801
I had a look at the hp site and there they mention that the servers comes with a hot plug  or cool plug power supply based on the model of server..
by: NCTERWPosted on 2009-11-06 at 05:52:45ID: 25759042
We had a customer's server that would power on long enough for the lights on the motherboard to come on and the drives to start spinning and then it would power off so we called HP support. Although the server was out of warranty, the HP tech seemed to agree with us that it was the power supply and we ordered one from HP.
One of the employees of the customer went to a local office supply and bought a desktop power supply put it in the server and reported receiving the same results. The customer called us and told us it was not the power supply but the motherboard was the problem. We then ordered a motherboard.
Hopefully they will both arrive today.
