2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Top LCD & Plasma Solutions: 1 - 25 of 38
I have a Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark. The sound continues. The screen goes dark despite what's being dis...
I have a vista 32-bit laptop running vista business. I have just purchased  a new NEC 24" LED screen to work as an external monitor for it. When i first installed it was picked up the correct ...
I have a Planar PL1910M monitor that is giving me problems. The power light keeps going from green to yellow and back again.  Nothing shows on the monitor not even the menu.  Is there a way to...
I just purchased and installed a HP Pavilion Laptop Screen.  After turning on the laptop, I am getting a small red dot on the screen.  It only shows on Black, Blue and Green backgrounds.  It d...
Calling all experts: I have a Toshiba U205-S5034 laptop that goes blank (even tried external monitor) after the XP Logo screen.   - Tried all modes (safe, good last known, etc). - I am ab...
I'v got an older Compaq computer with Windows XP. It is slow to bootup. The 17 inch flat screen monitor Viewsonic A70f+ model: VCDTS23103-4R is in a mode that turns itself off in 5 second...
Morning all, I have a client that keeps getting what looks like interference on her LCD monitor. It appears as small vertical lines that are light blue and pink (about 1cm in height) tha...
Hi Experts, Does anyone have, or has anyone seen or made a portable/collapsible LCD stand?  The application is for traveling auditors who will take a 17" flat panel with them for dual monit...
Got a new screen for my Acer Aspire 6530, and started to take it apart and am completely stymied!  Anyone have a link for disassembling one of these?  The front bezel continues down on the the...
I like to know all you expert's thought on this .. Whats the typical or average lifetime of an LCD monitor? & Do LCD monitors last as long or longer than a CRT monitor?
Hello We have 5 HP Compaq 6715B AMD Turion64  and ATI Radeon 1200 series. All computers hang with white and gray vertical lines. It happens once a day, or once a month. Installed with ...
I've installed a Nvidia Quadro FX 4600 card in a Dell T3400. We have a 42in Wide HDTV and a 20in wide Dell monitor hooked up configured for clone. Now no matter what resolution/display factor ...
I want to buy an inexpensive SATA blu-ray player for a Windows XP PC, then connect it via my DVI port on my video card,  to my 42" LCD 1080p television (using a DVI to HDMI adapter).  Will I b...
I have a desktop which I am going to upgrade the monitor size I use to 24inch.  The 2 products I am looking both are 'Full HD' and have a 2ms response time.  However, the cheaper one has vga i...
Hi, I was wondering how I would connect 6 monitors to one workstation? Do I need seperate cards if so which ones, and do I need any more power - I have 4GB of RAM. quad core 6600 processor...
Hiello, I cannot use my monitor Hanns G HW223D on my laptop HP 6730b under Windows XP because it's not possible to choose the resolution 1680x1050 in the control panel or Intel monitor pane...
Hello, I want to buy samsung ld220. http://reviews.cnet.com/lcd-monitors/samsung-ubisync-ld220/4505-3174_7-33499494.html http://www.laptopmag.com/tag.aspx?tag=Samsung+LD220 but t...
I'm having problems  showing presentations on the right monitor.  I've had no problems in the past but displaying on a plasma screen as monitor 2 using extended desktop it won't work.  The pre...
I just change the Screen and Flat Ribbon Cable (new) but, it does not fix the problem. Laptop works fine with external monitor. Belore change the screen the computer had black screen. What ...
I just change my laptop screen (New) and I only get a White Screen. The laptop works fine with external monitor. I believe the problem is in the ribbon cable. So, where can I find the exact...
Hi, could anyone recommend me a good LCD monitor 22" or 23" for a desktop computer. Looking for a price range of not more that $250-350. Currently thinking about the following monitors: 1)  D...
Hi, I have a JVC genessa 42". Right now the bottom pixels are dead for about 5 inches up from the bottom on the right side of the screen. Is there any way that I can have the tv make the sc...
I am researching monitors to connect to my laptop.  I do a lot of graphic work so I want one that displays color as accurately as possible (can't currently afford a calibration device--but I k...
My neighbor says he is legally blind. There is evidence to the contrary, but he went to a 5 week school for the blind and got a computer. The monitor is a Dell and flat screen. Diagonally I'm ...
Hi, I have been asked to provide a large screen display in an office to show various key metrics which are updated in real time. I have written a simple web page which connects to variou...
