Time Tested NIC Cards / Adapters Solutions: 1 - 25 of 289
I have a desktop running WinXP which is connected to the internet via LAN Broadband (i.e. the internet connection is through a LAN cable and I need to launch a client to login). I have a lapto...
Hello Experts, I have an eval version of Windows 2008 server running on a machine for testing and I am using the Hyper V service to run a virtual server within 2008. The virtual server is w...
This happened after spyware/virus removal. Network card is an Intel(R) Pro/100 VE  diagnostics test ok. I have performed the following attempts to repair 1. remove and re-install NIC 2. ...
I removed Hamachi VPN software from my computer. However, the Hamachi network adapter is still in Network Connections. How do I remove the Hamachi adapter from the Network connections list? Th...
Hi All We are using HP PC's, running Windows XP OS's. Normally, to check what the NIC's speed/duplex settings are, I would go to network properties, etc. I was wondering if there was ...
DearExperts,                        i have a acer laptop model number aspire 5570Z, it is not installing its wireless network adaptor, when i gone in system information and thereunder compone...
I am using a Dell D420 with Windows Xp.  I am aware of the Internal Network Card Power Management problem that you have to set the settings to Always Activate on Battery.  However, it seem rec...
Hello, I have a network adapter issue. My Server has 2 physical NICs, but when I try to check TCP/IP configuration on one of them, I get a message like this: " The IP Address x.x.x.x is alread...
I've got a problem trying to configure my Dell Optiplex 745 (and I assume my 755) to wake up on lan from a powered off state.  I have enabled the wake up on lan option in the bios, but my mach...
I need to Team two Intel pro/1000 onboard nic's into a 2GB RLB via two trunked ACLP ports on my switch, but the option in the intel pro/1000 setup screan for team with other adapters is grayed...
Im having a problem with a Cisco Catalyst 2960 switch.  Student deleted flash on this switch (maybe 2 months old) and Im having to put a new image back on it.  Here goes!  I had another swit...
Here is the description of the hardware and the steps I took to resolve the title issue...without success :( Windows XP Home, Gateway laptop Lynksys WRT300 Router, no encryption no mac fil...
Anyone know how to untick (or disable) items in the inside the properties of a Network Connection via a registry modification? In our domain we are using Lumension Sanctuary Device Control ...
Dell Poweredge sofware 2 X Broadcom NetXtreme Gigabit Ethernet NIC's Win 2003 SBS Hi, How can we bond our Broadcom NetXtreme Gigabit Ethernet NIC's for redundancy? YB
Experts!  I have a Broadcom 5782 network card that I need to put into promiscuous mode so I can test my Websense connection.  How do I do this?
Hi All, background 2003 server sp1 PS4 HP Proliant 140 G1 Broadcom NetXtreme Gigabit NIC this has happened to me before and all i could do to fix was to rebuild the server. sympto...
I have recently purchased a number of Dell Optiplex 760s.  I am attemtping to image them using my current RIS images.  I keep running into the message that " the operating system image you sel...
I have several Intel servers with 2 NICS in, only one of which is used. These server are DC and file servers. - Is it worth teaming the NICs to make use of the one I am not using? - Do I nee...
We use BartPE for Ghosting PCs, however I can't get it to detect the Intel 82566 NICs in the new Dell PCs. The machine in question is a Dell Optiplex 755, with the Q35 express chipset and a...
I have a Poweredge 2900 III with four NICs running Server 2003 Enterprise.  I would like to create a team of the four NICs acting as one IP address.  All NICs are Intel brand.  Is there a soft...
I have been having trouble in the last 2 weeks connecting to a wireless connection from this laptop. This is a new issue. I was traveling much of the time and sometimes could connect and somet...
I seem to have a conflict with my on board nic card Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC Form time to time the system will lock (Blank, Black screen), No error msg at all Fo...
Hi, I have a Dell PowerEdge 2900 server with two Broadcom NetXtreme II NIC´s; I already found a lot of information about it, but nothing related to my question, my difference is that I ...
We have several IBM x3550 and 2 IBM x236 servers. I was wondering if the servers on the IBM platform have something similar to HP's iLO (Integrated Lights Out) to where there is a dedicated NI...
My son has just had his motherboard replaced under warranty. The new board is an ASUS M2N6B-VM. The ethernet controller seems to be attached to the board but has no visible writing on it. The ...
