What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Top Networking Hardware Solutions: 1 - 25 of 155
Hello, I'm trying to upgrade my WRT54G2 v1 device from the DD-WRT.com website, but can't seem to find the download.  Can someone help me.
I have a linksys WRT54G version 7 (firmware: v7.00.4). My home computer is configured so I can boot it with a wol magic packet. This works great in the LAN, but when I send the magic packet ...
I have a Dell 5324 switch and I need the command to reset the switch back to nits original configuration or default factory settings. Thanks
Experts, I have a server room thermostat placement question. Attached you will find a screen shot of a visio drawing of our new server room that will be built. Where would the best location...
Hello, I have a Cisco 7940 phone which was configured to use a SIP VOIP provider (voipfone.co.uk) and worked great for just under a year and it has suddenly stopped working. When the ph...
Guys, i have just bought a new cisco 1800 series router, conencted it up to my machine. but have forgotten how to log into it via command prompt, i'm sure it was something like - con...
Hi there I have a server with a dual port Intel Pro 1000 MT, and I'd like to setup an adapter team. Does anyone know which utility I should install and how I can go about setting this up? ...
I'm trying to configure SSH access to our ASA 5505 and ultimately disable telnet. I've gone into the ASDM and configured it to allow SSH.  However it doesn't work.  Any suggestions? Show...
I have a cisco 3560 POE switch with no flash on it. I deleted it to make way for a new one and lost connection. What is the quickest way to upload a new one?
I wanted to know the differences between these cisco IOS:  IOS XE, XR, and IOS
I'm having trouble connecting my HP laser printer to my network.  I don't seem to be able to give it the IP address it wants.  Can someone help?
My Cisco 1760 is already programmed and providing internet to the one fast ethernet port from my T1 connection.  I just now purchased a WIC 4ESW card that I want to install and connect more co...
I am looking to extend the range of the wireless network from one building to another, the range is about 140 yards, I am currently using two Linksys WRE54G wireless extenders but get a very p...
At our "primary" location, our company uses access-control lists on our perimeter Cisco router to reduce all incoming traffic to just the ports required for our DMZ servers.  Inside that we us...
I have an HP 4000m switch that I can connect to via serial cable. It has VLANs configured previously and i just want ti upload a new config to it. I can only use serial cable connection so...
Can some help. We have had a network issue over the last few weeks where some devices on the network have been taken the network down. We install 4 x Linksys switches the other day and the iss...
I set up WPA/WPA2 using 802.1x on an SSID controlled by a Cisco WiSM module. Radius authentication is working fine, clients are able to associate. The problem is the 802.1x Cert or the users c...
I have POS application on Touch screen.  I would like to send some orders to back kitchen area over the limit of the com port maximum distance. My OS is Windows XP Pro and newwork configurati...
The default MTU setting on this unit is 1492. I am having difficulty viewing some pages unless it is set to 1500. When I change it in the 2640B's Admin Interface and press "Save Settings" ...
How to configure a SonicWall Pro 3060, SonicOS Enhanced v.4.2.0.1 with two different blocks of external IPs? Originally, our ISP assigned us a block of external IPs in the range of 63.133.....
On the articles I have read it says that PortFast is configured on the Switch port that connects a Host.(I believe when you have a computer connected to that port). But If you have many compu...
I have a previously configured Cisco 1861 Router that I would like to modify the config on. I would like to use SDM or some gui. I have looked at the config via the CLI and it has many things ...
Looking to purchase two switches that will connect a SATA Dell PS4000 or PS6000 SAN with Dell R710 servers in a VMware environment.  This is for a small-ish company, and we don't have a ton of...
Trying to setup a Cisco 851W and I can't access the internet from the LAN.  If I console into the router I can ping addresses on ther internet but LAN user can't.  I also cannot get the SDM to...
I'm wondering if the following scenario will work.  I have a typical small office environment that I'm setting up.  My VLAN routing knowledge is a little rusty.  I'm deploying a VPN/Firewall R...
