Top Networking Hardware Solutions: 26 - 50 of 157
If I change the MAC address in windows XP how to know the real one and can i know if any user change his machine MAC Is there any commanded I can use to Know the real one?
Hi all, We have two 2960's that are connected to multicast sources/IRD's. Each IRD are transmitting multicast of various bitrate. The switch setup are basic with all ports in VLAN 1, so eve...
I have a Windows XP Pro on my desktop and I would like to have two gigabyte nic's on my computer. Would that double my speed. Say I'am on the network transmitting at gigabyte speeds would t...
Hi, I've got a legacy app which has multiple dial up modems and off site modems which dial in and out and transfer data. I was contemplating of cutting down the telco costs for the dial up ...
I have a Dell Power Connect 6224 as my Server Rack Switch.  According to dell it has a Switch Fabric Capacity of 136Gbps and a Forwarding Rate of 95mpps. Currently when I'm running a bandwi...
I am trying to get a BigIP up and running to load balance four web servers on a single IP network.  I am not able to modify the infrastructure. Here is what I have done so far... Created a...
I have two cisco 3810 routers and i want to connect it through serial port to serial port using a DB 60 to DB 60. My question is how can i configure the two routers in the same window opened.I...
Im trying to figure out why it gets stuck at configuring team please wait.... trying to team two intel pro 1000 cards. Its been saying that now for more then a day. os server 2008 x 6...
Can someone advise if it possible to partition off part of a Riverbed Appliance on the 550H model? Looking to setup a mirror of a servers directory on the appliance...Any help appreciated!
Hi, I have a Radware Linkproof 200 and have configured it with 2 ISPs. The linkproof sets up two default routes which looks correct to me as it should then load balance between the two. The i...
Hey Experts! I've got a new network up and running, but now I need to monitor my users web access. We've got an ASA 5510 and behind it there is a Linksys SRW2024 with 15 Users behind that....
I have a belkin router that has all 4 ethernet ports filled. I need another port. I have an old netgear wireless router, can I somehow connect this old router to the new one and increase the a...
Getting this weird error message, I'm not sure what i'm missing thats causing this I'm simply trying to copy the IOS img to a tftp server. I'm using pumpkin v2.7.2 as a tftp server soft...
Hello I have a Windows Server 2008 x64 Domain Controller/DNS server (dell poweredge 860 with dual Broadcom NetXtreme gigabit controllers) who, all of the sudden, decided it no longer wanted...
I am in the middle of trying to get this ASA installed and working.  I will attach my config at the end. I edited some basic things from the default config, I have a static IP block from comca...
I have a ricoh 1515 and have loaded the software correctly, all functions are working perfectly other than scan to file.  I loaded the scanrouter v2 and setup everything properly, delivery ser...
Need help on how to setup and or discover a Jet Direct J3265A device on our network. i have installed HP Jetdirect server softaware on my workstation but aside from the discovery pane I am abi...
I have an 871 Cisco router. I have rdp working to our server just fine through port 3389. I setup one of our other desktops to use port 3390 for RDP and I applied a nat to use this but it isn'...
Hello, I just purchsed the WAP54G and need assistance in setting it up.  I currently have another router (WRT54G) upstairs and need to physically connect (ethernet wise) something in the f...
I have configured up an 877w using SDM and have attempted to create an Easyvpn server on the device.  The router is working fine machines on the lan side can browse the internet. The easyvp...
My computer configuration: Window XP,  Lenovo 3000 N100, Adapter is Broadcom 802.11g. two weeks ago I could surf internet through the wireless connection. One day the wireless adapter of ...
Hello, More a question of what is popular opinion - but I'm looking for direction on certifications. In the last year I have completed my MCSE in 03 and will shortly be upgrading it to t...
Hi everyone. I have a client who has 3 locations: The "main" location where the server resides and two remote locations. The locations are networked via VPN using Cisco Pix 401 VPN firewalls, ...
I have an 1861 router with an older config on it. It has Call Manager Express configured etc. It also appears to have a certificate generated. What I simply need to have is this remote 186...
how do i tell if i am getting the performance i expect from my LAN. I upgraded to DLINK DGS-1224T switch, have a DLINK DIR-655 A4 Router, and 4 pc's "wired, not wireless" with windows 7 or vis...
