I have an 1861 router with an older config on it. It has Call Manager Express configured etc. It also appears to have a certificate generated.
What I simply need to have is this remote 186...
how do i tell if i am getting the performance i expect from my LAN. I upgraded to DLINK DGS-1224T switch, have a DLINK DIR-655 A4 Router, and 4 pc's "wired, not wireless" with windows 7 or vis...
I am doing a research in which I seek to find out the average or the approximate number of devices connected to the internet and their distribution (by type,region and application) nowadays. I...
I recently bought a linksys wrt160n router, but there are some spots in my house that aren't getting a strong enough signal. My old router is a SMC Barricade 2804 which I'd like to setu...
I am in the middle of trying to get this ASA installed and working. I will attach my config at the end. I edited some basic things from the default config, I have a static IP block from comca...
I have a network consisting of the following:
Core: HP Pro-curve switch 5412zl-96G
Fibre Module: J8436A 10Gb SR (Multi-mode) transceiver.
Edge: HP 2910 48 port 10/100 /1000 +4 SFP PoE s...
Dear all,
I'm going to replace BIG-IP of F5 products to newer version...I do not have the experience on building it from scratch...but I'm requested to get configurations from current worki...
I have a managed switch (Powerconnect 6248) and I need to be able to make it to where only certain IP addresses can operate on certain ports. I have read into DHCP snooping with MAC/IP binding...
I have had a dedicated fiber optic connection in my apartment for a couple years, but the company is terminating the service so I need to choose between a shared fiber optic connection and the...
I need a compact power cord for a network switch. The cord is a standard computer power cord, but there is only about 1/2-inch clearance between the switch and the rear of the rack in which i...
Hello, I'm running into some difficulties configuring port mirroring on a Dell Power Connect 3548. We are running surf control web filtering software on a file server that's running Windows S...
I have 2 real servers which have ssl and http ports configured. I have an http content check which checks a specific page. Thei healthcheck works as expected, however when it fails, t...
Hi guys
I have been told to provide a solution to a company which is alredy equipmed with Enterprise Mcafee antivirus.
The purpose of this solution would be to mitigate those virus , malwar...
I have a new one of these at a client side and need to be able to ssl-vpn and then vnc to the desktops for remote support. I am familliar with the SonicWall ssl-vpn, but cannot get this one to...
What are the top and best Open Source and Commercial Proxy Server Software's ?
My ethernet cables are not working although on the shorter length the same configuration is working.
If I try the sorter length it works but the longer which runs through the cable fitting ...
Hello experts,
Please, I wish to learn PRACTICAL things about installing LAN card, switch LED colors, configuring TCP/IP address etc.
I dont have sound knowledge in Networking.
Please su...
Further to a related solution posted by i2q2 below, regarding help setting up internet access in a public place but keeping the public access isolated from the private LAN I have further quest...
Hi
I have Linksys Router with inside ip=192.168.1.1/24 ,Outside ip=10.32.1.0/24.The outside of Linksys is connected to inside interface (10.32.1.0/24) of 1811 router and this 1811 is conn...
Setting up a new Dell E6500 for my company, the past couple of machines like this that have come through have had this gray and blue arrow in the title bar. I never notice it until I am done s...
Hi Experts,
We purchased a new router 1812 ,1st time i connect through console with pc and access with hyper terminal. At login i typed cisco and password cisco. After that i rename Cisco ro...
I am getting ready to setup a remote office of 3 PC users, 3 IP Phones, and an ip printer. My idea is to setup the other facility with a private T1 backbone with a different IP scheme at the ...
I have a Cisco 3750 core switch in a remote site with the following details
model - WS-3750E-24TD
SW Version 12.2(35)SE5
SW Image C3750E-UNIVERSAL-M.
It has rebooted unexpectedly on a ...
My remote office occasionally loss the connection to my Corporate server through VPN connection. When it loss the connection, I take a look of the ASA interface statistic but actually, it doe...
Dear Experts
I tried to set a lab using a catalyst switch 3550, a client pc and a server installed with windows server 2003 , the main puropse was at allow a PC client to authenticate to t...
