I have a 24 port cisco 2960
wi th the following s/w
c2960-lanbase-mz.122-35.SE5.bin
I am looking to buy a spare that will cover all our edge switches should we get a failure and have sett...
I'm having trouble accessing my sling box from outside my network. I've tried lowering the firewall on router. Tried forwarding port 5001 through port 5500 and still doesnt work from out...
A while back socalsuperhero answered a related question about creating a VPN tunnel at home and suggested using a PIX 501 as part of the solution. Here is my setup:
At Home
ISP is RoadRunne...
I have a Cisco 861W router that I cannot seem to get working properly. I can configure the LAN and WAN interfaces and can ping DNS names or IPs from the router and everything works correctly. ...
OK, a problem from home which, if anybody with good networking skills (probably an understanding of subnetting) could help with I'd be eternally grateful!
I have two wired/wireless routers ...
Hi there
I am looking for some suggestions on which wirless router will have the best throughput to take advantage of the new 50/10 internet service that I have in my office.
I would rather...
Hi there,
I'm trying to set up a remote access to a Avermedia 1304EB Net drive for a friend.
This will allow my friend to access the CCTV cameras from his home.
The Avermedia drive is c...
We are in need of a Hub for a network packet listener application. The device we want to listen to is connected to an unmanaged Switch. We want to introduce a Hub between the Switch and the d...
I need to create a network in which two segments are secure from one another while they both share Internet Access, a NAS, and a network printer. I'm wondering how this could work. If I con...
Has anyone had any experience with SmartNet alternatives from 3rd party such as NHR, etc?
www.networkhardware.com
Interested in getting feedback on support experience and replacement part/...
A customer of ours has two buildings about 100M apart with a small network in each. The networks have been linked for about a year by two Aironet 1310s acting as point to point links. 1 w...
I have an xbox 360 and an 881w router. My xbox is directly connected to my router, not through the wireless since I have not set that up yet. I am able to connect to xbox live but I always h...
Is it possible to set up a guest login web page, without a Wireless LAN Controller? I have 3 Aironet 1250's.
Is there any way to monitor the bandwidth usage of 1 port on an HP Procurve 1800-24G switch?
Hi experts
So, I done this before recover a password no big deal, and now I run into a chalange... I am just unable to get to the bottom of this switch...
this is what the DIR FLASH: looks...
Hi
Does Cisco has something that help translate 10.32.10.10 to 10.32.10.20 ?I have a requirement here where the destination for 1811 router is 10.32.10.10 (This is the host on the othersid...
I am getting the following error message from a Cisco Catalyst 3560 switch:
VLAN manager received an internal error 4 from vtp function vtp get domain info No such domain
Hello
I have a script with a line of code that lloks like this
xcopy \\%1\CardReader\DCIM\100_FUJI\*.* V:\Images\
xcopy \\%1\CardReader\DCIM\103OLYMP\*.* V:\Images\
xcopy \\%1\CardRe...
Hi Experts,
My organization want to subscribe monthly some good magazine for information technology
so that we can keep in touch with latest technologies and new products in the Field of IT...
Hi all,
I am doing my first network install tomorrow using a roll or wire and RJ45 connectors -I have the tools and have watched the guides on crimping.
I bought this cable reel:
http:/...
Hi ,
I have removed two vlans from my Cisco switch 3560E so after executing the command show vlan I don“t see them there anymore, I have also saved the configuration to the startup file .
Hey folks. I have a weird question. In our offices, I have drops with voice and data locations in each drop. The voice and data are on different networks and the voice lines are connected to P...
I would like to know how to enable ESMTP over TLS. I have an ASA 5520 with the following version:
Cisco Adaptive Security Appliance Software Version 8.0(2)
Device Manager Version 6.1(1)
I just bought a cable tester.
Good for testing cable with open or shortcut circuit.
Now i want another thing. If my cable is good. i want an affordable tester to test the speed of this cab...
hi,
We are using Semantic antivirus coporoate edition.... we can not find the password to open. it.... is there any way to retrieve it?
