opton 1: EXPRESS IBM x3200 M2 2.53GHz 2GB 2x250GB SATA
Core 2 Duo Intel E7200 2.53GHz; 2GB (4x 512MB) RAM
Integrated Serial ATA; Tower;2 x 250GB Simple Swap
SATA HDD (RAID1 enabled)
10006f...
Hey everybody, Got a good and urgent question!!!
I ran a CAT5e cable from a T1 demarc to a router about 100ft away and then ran a cable from the router to a cisco 2950G-24-EL swtich but I h...
how can i team two nics for fault tolerance on a win xp pro box.
I'm trying upgrade from a Pix to an ASA and I used to Cisco tool to convert the code. Everything worked fine except for the crypto map commands
The following happens:
ASA(config)# crypto m...
Good day everyone,
Soon our comapny will be deploying a vritual enviroment and we will be going with EMC for our SAN device. I wanted to ask which would be the best 34 port cisco catalyst g...
I just started playing around Windows 2008 Standard (RC) in a test environment. I cannot for the life of me get it to connect to the internet. I have loaded the latest NIC drivers for both of ...
Hi
I have Site A and Site B connected via LAN-X.I brought in secondary LAN-X for backup purposes and tried to implement it using static routes for the fact that ONLY static routes be used t...
I'm looking at routers at Sonicwall. Some have SPI and some are supposed to be better with "Deep Packet Inspection"... I'm whitelisting a few url's for a business computer. I want to protect i...
Shouldn't be too difficult for someone in the know about these things, I've got a Cisco 4402 (WLC), and a Cisco 3750G-24TS-1U switch. I'm trying to configure multiple VLANs on the switch and ...
In our office lies about 10 older 6 port Netgear network switches EN106TP.
Most of our devices are now 100/1000Mbps.
I would really like to make use of them.
I've googled but couldn't fin...
We have a network tester, but it's expensive so only our network people are allowed to use it. For our building support people, we would like to get something inexpensive that will just let u...
I need to purcahse 2 switches, most of the infrastructure is using Cisco but they are very expensive and only come with a 3 month warrantly. I require 2 switches to implement to vrrp be...
We are having problems connecting an HP Flex-10 module (via Fiber) to a Cisco 3560E switch. We are not getting a link light at all. The SPF in the Flex-10 is HP Part number 455883-B21 and th...
I need to setup a second IP for my fiber connection as one of my servers will be hogging port 443 and I need to setup an ssl-vpn also onto the fiber connection.
I've been reading th...
Why is it that a 1Gb equipped PC connected to a 1Gb switch port never uses the full 1Gb bandwidth? Actually, it appears to never use more than 20% of its "alleged" bandwidth. I've monitored ...
What is the best way to test new gigabit UTP network? Lets say there are 30 PCs in a network and I am interested in testing of switches and cables? What is the best software way to do this? Is...
We are using HP Blade centre Solution in our datacentre, we have our web servers and DB servers in the same chasis . As a statuory requirment we need to place DB servers in DMZ segment. N...
I have internet service through a DSL service. I have a box from them which is directly connected to my computer. I also have an internet phone which is directly connected to my computer. I ad...
I have sales reps that use laptops daily. They log on to the local laptop and process work when they are not connected to the domain. What is the best practices way to set them up? I inheri...
I have two cisco 11501 that I bought on ebay. I can access one of them alright. The other one has password setup at the Offline DM Menu and on the system.
I read at cisco that I should contac...
attached is my code for my router. I have verizon fios at home, and for some reason my cisco router, which is an 881w, can ping the internet like google.com but my pc cannot. My pc can howev...
I have recently purchased this router. Setting up the Internet access was no problem. I have done this many times; however, this is the first time I have setup VPN clients on a router. The ...
Hi Friends,
i am testing an simple network in GNS3 Cloud<----->R1(router)<------->R2
R1 fa0/0 has 192.168.0.2/24 ip fa0/1 has 192.168.10.1/24 and R2 fa0/1 has 192.168.10.2/24
problem ...
HI,
How can I enable http and https on PIX 506 so I run the SDM.
Fuad
I am looking for floor-mounted (flush or recessed) boxes or floor-plates that provide either:
- RJ-45 ports
or
- RJ-45 ports and electric sockets
The products should be available for ret...
