Hi there,
We have a new client that has a main 24 port switch. Yesterday they were having network problems where some computers would not renew their IP Address. I checked the DHCP server a...
Dell Optiplex GX150 and Windows xp sp2. Cannot get network cable to work. No nic card lights. Have tried 3 different machines and 3 different cat5 cables. IT insists port is live, and a wired ...
We have a number of SMC6724L2 switches. They are running firmware version 1.24a, which according to the switch was published in 2000. A check on the SMC website shows the latest firmware versi...
Hello!
I have a Cisco ASA 5520 ver. 8.0.(2). I have set up the threat detection policies to "shun" active threats. I see several Scanning and SYN attacks that happen throughout the day bu...
Hey there,
I need some help determining which L3 switch I need to use. My goal is as follows. I have an internet connection, either a t1, cable, or dsl and a router, either a sonicwall or a...
The server has said there is limited conectivity and may not be able to access internet or other network resourses. The network did not assign a network address. Our router had a problem last ...
My ISP provides me with 8 IP addresses. I'm trying to setup my routing on the ASA5505, to use those IP addresses.
The ISP Vlan is defined as x.x.x.225 255.255.255.240 so (225 thru 238)
I would like to exchanges files between several laptops without using wireless connections, or a hub o a switch, by using two routers. I attached a diagram to shorten explanations. I dont nee...
I want to setup a router in my car with a Wireless Broadband Data Modem.
I have a USB Wireless Broadband Data Modem that I can plug into my laptop - but I want to plug it into my router i...
Can I set multiple DHCP scopes on a Netscreen firewall? If so what model numbers are supported?
Thank you.
I want to add a second router to my network, right behind the one Comcast provided my small business. I have a VOIP server that requires a lot of ports to be forwarded. However, my Comcast r...
Auto-Negotiation is not enabled on the
device. The adapter has been configured
to force the speed to a low speed.
I receive this Info message when I run testing on my NIC. M...
I'm putting in a point to point T1 from my boss's house to the office. I don't have any other ISP options at his home. We have a DIA T1 at the office and I'm buying 2 Cisco 1720 routers with...
Greetings,
I'm looking for recommendations on six Gb hubs that I will be placing under tables in a training room. The environment is SBS2003, with network Gb Switches and CAT6 cabling. I ha...
We are looking at supporting a 176 unit condo building. We need to provide everyone with internet connectivity. Some people will have static IPs some will have DHCP natted IPs. We are looking ...
I'm having DNS resolution problems with a Cisco ASA-5505 which I'm hoping someone here can help me out with. I've read quite a few other posts which haven't answered my question. I am runnin...
I am trying to configure a router for an AT&T T1. What do I need to use for my default route?
I've been given the following information
WAN Information:
WAN IP Address/AT&T Router IP A...
I have an ASA5505 hosting our internet connection. I'm trying to setup it up to allow VPN traffic through to our domain controller. Here is the ASA5505 configuration so far:
object-group ...
Hi
I have ASA 8.0(4) with 6.1(3)ASDM.Suddenly I cannot access ASA using ASDM although I see login bar progressing after entering username and password and sitting there,I still have SSH ac...
Experts,
I'm on Fedora 8 and have installed a driver manually using insmod. Every time I reboot I 'lose' the driver meaning it's not listed in lsmod and the device only works after reinstal...
Hi
I have 1811 router.It has FastEthernet and Dial up Interface.I want to use this router to connect to Internet via FastEthernet as Primary Connection and if this fails I want to connect ...
I'm setting up our cisco 3560 and am trying to setup vlans. Basically, I believe, I have everything else, but I can not ping the other VLAN interface.
Here's what I've done:
ip routing
Please link it if you know
thanks
I need advice which mini-GBIC to buy in order to connect eight Linksys switches SRW2048
Hi
The attached JPG show my home network
When Im transferring files between pcs media player or the NAS, internet browsing slows down considerably & vice versa.
Im assuming this i...
