Password Recovery for Cisco Catalyst 2900XL, 3500XL, 2950, and 3550 Series Switches
AID: 205
  • Status: Published
4047 points
The worst thing when starting a new job is when the previous Network Administrator left behind no documentation. How do you get into the devices? If you've been in this situation or just accidently mistyped your password, this article will hopefully shed some light on your problem.
Console to the device
Console into your switch using a console cable an a program such as HyperTerminal, CRT, SecureCRT or Putty.
Enter recovery mode
Unplug the power cable. Then, plug the power cable back in WHILE holding the mode button located on the front panel of the switch.
Note: For 2900/3500XL and 3550 Series switches, release the mode button after the LED above port 1 turns off. For 2950 Series switches, release the mode button after the STAT LED goes out.
Initialize the flash
switch: flash_init
Issue the load_helper command
switch: load_helper
switch:
View the flash
switch: dir flash:
Rename the current configuration file
switch: rename flash:config.text flash:config.old
switch:
Boot the device
Type "boot" and press enter.
switch: boot
Cancel the the system setup
--- System Configuration Dialog ---
At any point you may enter a question mark '?' for help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Continue with configuration dialog? [yes/no]: n
Press RETURN to get started.
Enter enabled mode
Switch>en
Switch#
Rename the configuration
Switch#rename flash:config.text system:running-config
Copy the configuration into the running-configuration
Switch#copy flash:config.text system:running-config
Change the password
Switch#configure terminal
Switch(config)#no enable secret
Switch(config)#enable password NEWPASSWORD
Save your new password
Switch#write memory
2008-11-20 at 19:42:51ID205
Cisco
Catalyst
Password Recovery
Switch
Network Switches & Hubs
Views
3296
Add your Comment
Please Sign up or Log in to comment on this article.
Join Experts Exchange Today
Gain Access to all our Tech Resources
Get personalized answers
Ask unlimited questions
Access Proven Solutions
Search 3.2 million solutions
Read In-Depth How-To Guides
1000+ articles, demos, & tips
Watch Step by Step Tutorials
Learn direct from top tech pros
And Much More!
Your complete tech resource
See Plans and Pricing
Top Switches / Hubs Experts
  1. nazsky
    98,200
    Master
    0 points yesterday
    Profile
    Rank: Wizard
  2. TimotiSt
    74,882
    Master
    1,000 points yesterday
    Profile
    Rank: Master
  3. donjohnston
    74,477
    Master
    3,236 points yesterday
    Profile
    Rank: Genius
  4. eeRoot
    68,515
    Master
    0 points yesterday
    Profile
    Rank: Wizard
  5. giltjr
    43,400
    0 points yesterday
    Profile
    Rank: Genius
  6. Soulja
    41,765
    Profile
    Rank: Genius
  7. mat1458
    40,360
    0 points yesterday
    Profile
    Rank: Master
  8. fgasimzade
    39,268
    0 points yesterday
    Profile
    Rank: Wizard
  9. Netty
    33,192
    0 points yesterday
    Profile
    Rank: Guru
  10. hanccocka
    31,488
    0 points yesterday
    Profile
    Rank: Genius
  11. RKinsp
    24,901
    0 points yesterday
    Profile
    Rank: Master
  12. jodylemoine
    20,900
    0 points yesterday
    Profile
    Rank: Sage
  13. craigbeck
    17,704
    0 points yesterday
    Profile
    Rank: Sage
  14. erniebeek
    17,336
    0 points yesterday
    Profile
    Rank: Genius
  15. mattvmotas
    17,225
    0 points yesterday
    Profile
    Rank: Sage
  16. Rick_O_Shay
    17,198
    0 points yesterday
    Profile
    Rank: Sage
  17. ikalmar
    16,244
    0 points yesterday
    Profile
    Rank: Genius
  18. ArneLovius
    16,132
    0 points yesterday
    Profile
    Rank: Wizard
  19. gsmartin
    14,001
    0 points yesterday
    Profile
    Rank: Master
  20. rigan123
    13,259
    0 points yesterday
    Profile
    Rank: Guru
  21. lrmoore
    11,882
    0 points yesterday
    Profile
    Rank: Savant
  22. Kvistofta
    11,358
    10 points yesterday
    Profile
    Rank: Sage
  23. jburgaard
    11,300
    0 points yesterday
    Profile
    Rank: Wizard
  24. agonza07
    10,907
    1,500 points yesterday
    Profile
    Rank: Master
  25. lruiz52
    10,500
    0 points yesterday
    Profile
    Rank: Guru
Hall Of Fame
