Main Topics
Browse All Topics Hello,
Having issues getting (anywhere) near the full bandwidth capacity of our 10/10 fiber connection using the a SonicWall TZ190W we've recently purchased. The appliance is pretty much set to factory default settings, minus the information...
I have a fortigate 60 and can not find the password that was originally set with the box. There is a way to connect to the box via a console cable and reset the admin password. It is something like this:
If you have console access to this...
I need to configure my router to connect to an ISP providing cable Internet. The ISP has given me a static IP, and claims that they only need a MAC address from me in order to supply Internet.
Initially I provided the address on a PC NIC, and...
A colleague has asked a question about some discard rates he is seeing on one or 2 switchports. they have surpassed a threshold limit of 10%.
Can somebody tell me what are all the possible causes of high discard rates on an interface?
At work we use a Canon imageRunner 3570 multifunction for our copying. This unit also has the ability to print so I found the drivers and installed them, then I sent a job to it and the job did not print. The job log on the copier shows that the...
Hi!!
Is there any color coding for Fibre optic cables??? I have seen that in MDF it is generally yellow.....like earthing cable is green??? In MDF room, what are the MUGS...what they stands for and what is the difference between MDF and DDF???...
I manage a network of about 100 computers. It drives me insane when people don't leave their computers turned on and I have to walk halfway across the building to do any maintenance... And then the door is locked!
I have Wake On...
Could you help me find the way to reset D-Link DP-301P+?
Because there is no reset button on the device.
Thank you.
I am attempting to reset a Dell PowerConnect 6248 to factory defaults. I have issued the following command from enable mode:
clear config
I then attempt to copy the running-config to startup-config by issuing the following command:
copy...
This was a working system until the modem got reset. I have established internet connection with the provider by porting a pc through the modem. The sonicwall is still connected but when configuring modem as a bridge I still have problems. The...
Hiya Everyone,
Just looking for some advice. Its been an issue for a while, and although i have a workaround, i want to know the opinion of someone who knows a little more about this.
I have some HS22 Blades, in a BladeCenter E Chasis,...
Hey guys.
I have a Cisco MC3810-V and an 871W. The 3810 has a Console and AUX port. It is possible for me to hook me computer up to the console port of the 3810, then run a cable from the aux port to the 871's console port, right?
I have...
Hi There,
Here the scenario: Two Radio links between two sites - one Bridgewave microwave and the other Orthagon standard spread specrtrum.
The Microwave is a Gig link and the Orthagon is 18mg link.
The bridgewave needs to be used as a...
I have a Cisco 1841 left behind by the previous IT guys. They've only left a password with view level permissions and are uncontactable.
Does anyone know how to reset it to factory defaults?? I see no place to stick the paper-clip!!
I am unable to get the copier to scan to folders on the Win2003 server. To Xp boxes its fine. I am missing something on the server. When you browse to it it denies the user name and password even though it has Admin rights. Am i missing a setting...
Hello guys!
Im having problem reseting my 3com switch 4500 26-Port to factory default settings. I found a 11 pages release notes document on it here(http://support.3com.c
We have just installed the SonicWall SSL VPN and when a remote user tries to login the sonicwall give the user the message "User has no privileges for login from that location" This is also what shows in the sonicwall log. The user is setup in...
Hello
I need to reset the internal admin password on a Konica MInolta BizHub C350.
There is no mention of this in the manuals and I can't find any answers online.
Anyone have any experience with this box?
Hi Everyone,
I am in the process of configuring a new Dell Powerconnect Swtich but would like to know how to configure the SSH administration so that I can login and administer it from my desk and not have to be plugged in via a Serial...
I have a number of HP Proliant DL 380 servers running Windows 2003 Standard Edition and for the past 6 months I have been having a problem with the servers rebooting automatically (ARS). The server is generating System Event ID 57 repeatedly and...
What my focus is to access three systems remotely thru web pages by giving different port nos. i m getting the remote desktop screen and i can put the ip address of remote system after the configuration of port forwarding in juniper ssg 140...
I am looking for job in UK as a network engineer OR IT support andI have created a CV after a long research because its come in to my knowledge that its very important to find a job that the person have the very good CV. I will very much...
Hello Experts,
I have an HP ProCurve Switch 2848 switch connected to a Cisco catalyst switch. The HP port is reporting excessive jabbering, and we think this maybe because Jumbo Frames is not switched on the HP.
Referencing the...
Failed to initialize migration at source. Error 195887200. Necessary module isn't loaded.
The vMotion failed because the destination host did not receive data from the source host on the vMotion network. Please check your vMotion network...
I've got a number of Axis camera's at my location and all of them work with no problem. I am able to view the live feed and also view older videos via a web browser.
One of things that was requested from my higher ups was the ability to play...
Hi Everyone,
Have a router thats completely screwed. The only thing I can think of is rebooting in read only mode and wiping the flash as the whole thing hangs under normal bootup procedure.
Is it possible to do this? If so can someone...
Hi. We installed a ECC 6 Server (abap+java) with MSSQL 2005 with SID:T13 & updated all patches in the system. Later we did a system copy & named it a T14.
IN SE06 (post-installation activity); First we selected 'standard installation' instead...
I am having an issue with a new build of the juniper OS and it has dumped some of my standard configs and it is not allowing me to access 2 web servers behind the unit.
I have 2 web servers running behind the juniper one is using the egress Ip...
I have a Cisco 3750G switch connected to (among other things) 2 Cisco Aironet 1200 wirless AP's.
One AP is connected to port Gi1/0/31.
The switch is connected to our main building via a laser link (FSO) connected via port Gi1/0/1.
When...
Hello we are running a Sonicwall Pro 2040 with the 4.2.0.1-12 enhanced firmware. We recently upgraded to cable modem internet service from a 1.5 T1. If I hook a laptop with a static ip directly to the cable modem, I'm getting about 30 mps down...
Hello. We are having some trouble with our firewall.
Here goes :
We have a Sonicwall NSA 2400 updated to the latest firmware (SonicOS Enhanced 5.8.0.1-31o) providing internet connectivity to our lan users. However, at random interval,...
I have a Juniper SSG-140 and I seem to be having a routing issue. I am not very familiar with the management of the firewall, and only minimally familiar with networking. I have a system on my network that cannot access the internet. I went...
Not sure where to begin. Here goes.
Original network was a stack of 3 x Dell PowerConnect 3448 switches. The ports are all 10/100 and handle about 100 end users/printers, etc. The stack was connected to a Dell PowerConnect 2724 GB switch...
I went to the MySonicwall site but it only offers me "free" downloads, after signing in.
What does it take o get the latest firmware update for a TZ170?
Do I need to input it's serial number somewhere?
I want to enable failover so I think I...
Our employees are using thin-clients which work fine for all applications except watching video online, such as YouTube. The video is choppy and out of sync with the audio.
We tried changing the switch between the DNS and Terminal server to...
What is the default ip address for a HP Laserjet 1320 printer
Hi Everyone,
I am in the process of trying to configuring redundant Networking connections from My ESXi 4 host to my Dell Powerconnect Switch that is connected to my SAN.
I have added both Nics to my storage VSwitch on the ESXi and the...
I have a Fortigate 100A Firewall for the primary firewall for our organization. For the last few days I have been experiencing some very strange unexplained traffic coming through the firewall. The incoming traffic has been constantly at...
Hi guys,
I had a router blow up on the weekend and had to replace with an asus wireless router.
I copied all the settings and all the port forwards and things seemed to be going well.
the only problem I have is with one of our VPN...
I am using a Windows 2000 server doing DHCP and DNS in an Active Domain environment. I want to add a new 2003 Server and open my IP range to allow 192.168.102.xx and 192.168.103.xx ranges. Where do I start and can I do this without buying a...
Hello all,
Using Veeam 4.1 and Fast SCP I was able to copy a VM (actually 4) from an esx 3.5i host's local storage to an EMC AX4-5i virtual disk with a rate of about 30 MB/s (not great but good enough for now). Some time has passed and now I...
I have a fortigate 60 firewall on our network restricting access to youtube for internal users.
I'm wondering how I can add exceptions to this so that some users can access youtube?
I have tried a couple of options based on source IP...
I have two if these...one was NIB and it configured with no problems; the other was a "pull" from an office that was only up for a couple months. It worked flawlessly when first deployed. Now, I am unable to configure the device after performing...
We have currently just purchased a load of HP 8200 elite USDT computers which contain the Intel 82579LM network card. I am trying to get this working with our MDT 2010 deployment for windows 7 enterprise.
No mater what drivers i seem to use...
I'm assuming this is a simple question.
I've been configuring a new 3500yl switch to replace an old switch and I've got part of the config wrong. We have other 3500's in our network and I'm using them to base my config, but I've done something...
Hello all,
I am quite a bit more familiar with Cisco with regards to spanning tree. However, we have some Extreme switches running XOS 12.2 code, latest rev.
I need to uplink via a trunk/tagged port for 5 vlans.. plus provide edge port loop...
I am running ESXi 4.1 on a HP Proliant ML 350 G6 hosting 3 virtual guest Windows servers. One server is running Windows 2008 R2 64 Bit as a domain controller and DNS. The second server is Windows 2003 and is a print server, fileserver and...
Hi All
Just wondering if anybody would have the password recovery procedure for an Extreme Networks Summit X450-24 switch.
One of our network guys configured a n Extreme X450 switch a few days ago and cannot remember the admin password and...
I have a SonicPoint G running firmware version 3.5.0.0. I recently had to reset the unit to defaults. As I have learned, once the unit is reset to defaults, it runs in Safe Mode. Now this unit is stuck in SafeMode and I can't seem to do anything...
I am trying to connect via Cisco VPN client. Tech support at the remote computer end has no idea what the problem is, so for now I'm on my own. When I try to log on, I get the error: "Secure VPN Connection terminated by Peer. Reason 427:...
Tandberg unit has it's own IP available to access from the net. Dial it on other similar units by entering the IP.
As far as I know - Skype uses usernames, etc for contacting others (like MSN does).
Is there any way to establish a video...
I've got a Cisco 1841 that I'm trying to connect to the internet using a 3G cellular card, but it just refuses to work - I can not connect to the internet through a laptop connected to fe0/1.
Cell 0/0/0 is constantly jumping between:...
I have two procurve 3500yl switches.
I have 2 vmware esxi servers with 8 NICs each,
I have 4 vSwitches in each ESXi host. Each vSwitch has assigned two pNics configured with the default vSwitch Port Based Load Balancing. For each...
OK, guys. I've tried everything I can think of and researched til I'm blue in the face.
This is a laptop with XP home (was SP3, but I reverted it back to SP2) and Verizon Wireless (USB Modem) and VZAccess Manager.
This is my Mom's laptop...
I have 2 HP ProCurve 1810G-24 switches. I gave both of them static IP's when they were first configured. Had a power outage this morning and I can not connect to them using the static IP's I gave them. I know that they could have defaulted to...
We have a flat network connected via a HP procurve switch. About a month ago we had to do a complete network shutdown to install a backup generator. Nothing was moved or changed at all. When I brought all the systems back online I tested that...
Try to install the network printer sharp ar 5516s printer drivers using windows 7, please let me know the path or the url to download the sharp ar 5516s printer drivers for windows 7
We have a single Cisco 851W router, it was working fine until we needed to make a change and discovered we no longer had the passwords for it -- so we attempted the password recover procedure and lost everything.
Since the router no longer...
Hello guys and as always thanks for your time and expertise.
We have a Dell Poweredge 2950 and I need to calculate the power requirements for a ups. We're going to connect five of these servers into a ups.
On the power supply for the server -...
Hi Folks,
I have a cisco 5505 firewall, its been fine since I bought it, but I wiped the PC that had ASDM on it and now I cannot get to the 5505 either by http(s) or putty.
When I try to visit its IP http://10.5.0.1 it just says page not...
I am trying to forward an .htm attachment to someone outside of my domain. However, I get the following error:
Generating server: SSI-EXCHG2.Supreme.int
waltonguidry@gmail.com
Barracuda.Supreme.int #554 rejected due to spam content ##
I wanted to know the differences between these cisco IOS: IOS XE, XR, and IOS
I just bought a Netgear RangeMax WPN824v2 and can't get to it by it's default IP. I following the manufacturers step-by-step instructions on getting it set up. I have a wireless laptop and a desktop computer both running XP Home. Originally I was...
Hi, and thanks for reading!
I have my modem connected directly to a Windows Server 2008 box with 3 network adapters on it. What I want to do is to to dial the PPPoE connection using RRAS on the server, and then share that connection via a...
Hello experts,
Ive been trying to research for an answer to a simple question but cant get a concise answer.
What is a cisco cco account? What does it imply? benefits of having one? and how to get one?
I have been logging some pings to random workstations on my network, and have noticed intermittent spikes in ping times. roughly 5% of the time i am getting ping times between 2 and 6 ms. 1% of the time I am getting ping times between 20 and...
I just bought a HP Procurve 2650 switch, and for the life of me I cannot find the setting fro link aggregation! Is there anyone oput there familiar with the switch that can help me? I have procurve 4000 switches as well that I never had a problem...
Trying to setup 2 VLANs to isolate broadcast traffic and setup 1 port as the trunk that will ultimately connect to the router. Have configured the 2 VLANs, but cannot get both to pass traffic through port 22 which I want as my trunk line. Can...
We have a Cisco 3800 Router and just bought a 1-port 10/100 routed port HWIC card to use with it. It does not work in any slot and gives the following error message that can be seen through the console:
"WIC Slot. Unknown WAN Daughter...
Does Huawei B683 3G router / modem + wifi save the log of browsing history of the internet and the downloaded files?
thanks in advance
I purchased a used Cisco 2811. Now how do I force a reset on the device to return it to factory defaults? I have the console cable but can not telnet to the device.
hi,
I have a HP ML150 Proliant G6 server. Which is currently connected to Network1. As i see on the back of the server there are 2 network ports, mgmt & 1/mgmt.
Is there any way i can connect the server to a 2nd network (Network2) using...
I am using bluecoat proxy for http access to Internet.
I want to block uploading of files by users who are using this proxy.
For example any user should not be able to upload any files to any website or should not be able to attach any files in...
Hi All,
I have installed a CIsco ASA in our network, the firewall has 3 security zones; outside, inside and DMZ.
We have an application server in the DMZ zone which is connecting to a database and internet directory server in the internal...
I am setting up network infrastructure in two sites in different countries.
Both have 2 ISPs.
Both require remote access VPNs.
One the ASA in both sites I have setup 2 outside interfaces and 1 inside interface.
I have a tracked default...
Dear colleagues,
I am new to Juniper and have recently acquired a Juniper SSG-20-SB router for testing purpose. I am used to working with Cisco IOS and have configured several CPE services from DSL to Ethernet.
I am trying to find a quick...
I Need to reset Cisco 881 to factory defaults. How?
Hello !
We have a network of about 50 users and many of them use Vmware / Virtual pc so the number of computers that are connected is about 90.
How many computers can the Fortigate 60 handle ?, lately users have complained about network...
Hello Experts,
I am setting up A two node Hyper-V Cluster. When Doing a live Migration I see in the server rating that it says. There are currently no network adapters with network optimization available on Host .....
I see where to enable...
I have a Cisco 3845 router with a 4 port t1 wic and a newly installed DS3 card. The 4 port wic shows up fine and I was able to see it by issuing the #card type T1 0 0 command. However the DS3 card is not showing up at all and when I try to...
Hi Guys,
Just finish installing firebox edge 55e able to configure authentication and it all seems working but than I find out that we cant loggin I mean to say we can open the loggin screen of hotmail , gmail or any other web based email, but...
I got hp pro curve 2626 switch i want to update the software.i have downloaded the software from hp procurve. so can any body explain clearly and step by step what i have to do how i can update the software. the hp suggested TFTP and XMODEM...
Is it possible to tell the cisco IOS to send a test message to the syslog server to check that messages are getting through ?
I inherited a firebox x1000. It has a password on it but I don't know it. Does anyone know how to perform a factory reset? Note: it does not have a button on the back for any type of reset but it does have four buttons on the front.
Setting up new network installation. Purchasing POE+ 48 port Cisco Switch and 891 Router to support ip telephone, ip cameras and access points.
I've learned over time how to navigate to find answers for MOST anything on Cisco's site, but still find it a challenge to identify specific available features in different IOS flavors.
I'm trying to determine, VERY specifically, the...
Hi.
We use this switch for an lan-party, once an year.
Unfortunally, we cannot remeber the username or password we had last time.
Is there an way to make an total reset of the switch?
This is an hurry job, as the party starts tomorrow:(...
Hi Experts,
I need to commission a wireless LAN based on multiple Cisco Aironet 1130AG devices. The site is physically awkward as a single radio is not able to cover the whole area, although it is CAT5 wired. So my question is this; can I...
I have already posted a question for which I have had little response so I am going to tackle this bit by bit.
I have a Citrix test environment with a PS4.5 Server publishing Apps and another server running WI and an attempted install of CSG....
Is there any way to block a MAC Address from accessing the internet on a Sonicwall T170?
Thanks!
Shawn
Hey all! Ok so here goes: I have a Blade Center H with 2 x HS21 blades, 2 x Cisco Ethernet Switch Modules. I have configured both modules with static IP's and working on Blade 1 I configured it's first ethernet interface with a static ip, the...
On a Win7/64 with an Hp Laserjet P2055DN network printer, I get event 315 error 2114 (The print spooler failed to share printer Printername with shared resource name Printername . Error 2114. The printer cannot be used by others on the network)...
I want to retrieve serial numbers from multiple devices using SNMP. I'm just using the net-snmp.org snmpget/snmpwalk tools
I am finding that the SNMP OID for serial numbers is different on different hardware, even with cisco, for example:
I'm using Netgear FSM726 switches to setup 2 VLANS on a layer 2 network.
I have 5 of these switches linked via fibre GBIC.
> Each switch has 5 Admin PC's and 5 Office PC's.
> Admin PC's should be on VLAN1, Office PC's on VLAN2
> The...
My system recognizes my Network hardware, but will not install their drivers. When I choose to install, the system goes through the motions, but ends with a window that says: Cannot install this Harware. There was a problem installing this...
We are trying to troubleshoot why a particular 7206vxr is crashing. Here is a little background...We are loading the chassis with an NPE-g1 (1gb) and (5) PA-A3-T3' After configuring and loading we are getting what appears to be a software crash,...
I have the following hardware setup
1 x HP Procurve E5412 Switch
2 x HP Virtual Connect Flex Fabric Modules (Firmware 3.30) in a C7000 Blade Enclosure
(Each VC FF Module is using 2 cables to connect back to the switch, total of...
how do u find the temperature on a CISCO router ? what's the command
Hi
I really need som help with setting up a VPN tunnel.
This is what i have,
1: Laptop with mobile broadband
2: Win 2003 server with Watchguard Firebox X55e
This is what i want to do:
1: Conenct my labtop to my win 2003 server using...
We have a Netscreen 5GT (ADSL) model.
We are trialling an Asterisk IP PBX and I was told to forward the ports UDP 5060-5061 and 10,000 to 20,000 to the PBX.
We have one static external IP, lets call it A.B.C.D.
Our PBX is at...
Darr247
48,114
1,500 points yesterday
Profilecraigbeck
34,951
0 points yesterday
ProfileTimotiSt
33,498
0 points yesterday
Profilegiltjr
31,195
0 points yesterday
Profilemat1458
25,731
0 points yesterday
Profilenazsky
24,298
0 points yesterday
Profileerniebeek
23,582
0 points yesterday
ProfileMysidia
23,136
0 points yesterday
Profiledonjohnston
22,743
400 points yesterday
Profilehanccocka
18,468
0 points yesterday
Profileikalmar
17,948
0 points yesterday
ProfileNetty
17,574
0 points yesterday
Profilerigan123
15,527
0 points yesterday
ProfileeeRoot
15,448
0 points yesterday
Profileandyalder
15,320
0 points yesterday
Profiledpk_wal
15,100
0 points yesterday
Profilelrmoore
13,688
0 points yesterday
ProfileSoulja
13,404
0 points yesterday
Profilethinkpads_user
12,572
0 points yesterday
Profileharbor235
12,348
0 points yesterday
Profilefmarshall
11,851
0 points yesterday
ProfileRick_O_Shay
11,764
0 points yesterday
Profilekevinhsieh
11,100
0 points yesterday
Profiledigitap
10,000
0 points yesterday
Profiledanieldias
9,900
Profile
