We have a single Cisco 851W router, it was working fine until we needed to make a change and discovered we no longer had the passwords for it -- so we attempted the password recover procedure ...
I just ordered a Linksys WRT54GS Wireless Router... it should be here sometime this week.
This router will be reconfigured so that the WRT54GS will act as a Wireless Bridge. My reasoni...
I have a windows based network with multiple Windows Server 2003 servers. I am unable to access one of the servers through network neighborhood, and as a result, I can't access any of the sha...
2 workstations. Both XP Pro. Desktop and Laptop. Cannot map the drive. I've been trying to sort this out for my client remotely but have tried everything I can think of. Both workstations are ...
We have 1 internet T1.
The T1 is hooked to a Cisco 1700 router.
The router is hooked to a Sonicwall 3060 firewall.
This is then connected to a Dell gigabit switch.
The server is connecte...
HI,
1. I got confused related to "Straight Cable"
2. Per my understanding the correct one is BROWN > White-Brown > GREEN > White-Blue > BLUE > White-Green > ORANGE > White-Orange
3....
We are in the process of planning a migration from a frame-relay network to mpls. We will use the mpls network to connect over 100 remote sites to our corporate office. The corporate office wi...
I am having problems with all Networking devices on my Dell Latitude D505 running windows XP sp2. It appears to be up to Local Area Connection 7?? Where do you remove all previous installatio...
I no longer have a image on my 3750. I now cannot break into rommon and it goes straight to a switch: prompt. I have never had this problem before, any help would be great!
I need to replace a Netgear Power Adapter for a WGR614 Wireless Router. Multiple Problems, Netgear will not sell me the power adapter, stating they do not stock the part & the warranty is done...
We all know there are IP Cams, however, is there any IP based MICROPHONE?? Only audio, no video, some wireless IP microphone??
Is there such device??
I have a linksys WRT54G version 7 (firmware: v7.00.4).
My home computer is configured so I can boot it with a wol magic packet.
This works great in the LAN, but when I send the magic packet ...
Can someone tell me how to set a baud rate back to 9600 on a 3560 running: flash:c3560-advipservicesk9-mz.122-46.SE.bin
A while ago I blew out the flash and accidentally reloaded an...
we just got an asa and our ISP has giving us a /30 ip address to route traffic to us and a 10.2.0.0/24 for our public network. We would like to set a private network with a 172.10.0.0 on the i...
Router: Linksys RV042 (Firmware Version: 1.3.12.6-tm)
NAS: Synology DS207+ (Firmware DSM 2.1-0839)
Having owned a few Synology NAS, this particular transfer rate is extremely slow. When ...
Hi
I really need som help with setting up a VPN tunnel.
This is what i have,
1: Laptop with mobile broadband
2: Win 2003 server with Watchguard Firebox X55e
This is what i want to ...
I want to retrieve serial numbers from multiple devices using SNMP. I'm just using the net-snmp.org snmpget/snmpwalk tools
I am finding that the SNMP OID for serial numbers is different on ...
I purchased a Sony Blueray netfilx read device but the back of it only accepts an ethernet jack to connect to the LAN. (at Home). The Ethernet at my home is not anywhere near the Netflix box...
Is it possible to configure Linksys Wireless-G ADSL Home Gateway (model WAG200G) a ROUTER for a PC (through cable) and a laptop (using wireless)?
If yes, could anyone write down step by ste...
Delete flash:C3750blah will not allow delete; message "error deleting flash <filename_blah>is a directory". What's the workaround? How does one delete a file w/o access to the directory struct...
Treing to setup a romaing user client to test with D-link DS-601 VPN software agianst their SMB/enterprise firewall DFL-700 I recieve an error saying: "Invalid payload type"
Log from ds-601...
I'm writing an Excel 2007 macro and I want to select a certain range from my active worksheet.
I tried using this:
currRange = ActiveSheet.Range("List1")
But I get the error number ...
I want to know what is the equivalences of a few IOS commands for the CATOS. Also, if someone can point me out a link where I can see the comparison that would be helpful.
How do you enable a...
Apparently some of our employees are pulling network cables out of computers and hooking up their own laptops when nobody else is around. Is there anyway to lock these cables into the slots s...
We have a flat network connected via a HP procurve switch. About a month ago we had to do a complete network shutdown to install a backup generator. Nothing was moved or changed at all. When ...
