2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Time Tested Networking Hardware Solutions: 51 - 75 of 841
I am trying to open port 8484 on Verzion FiOS. I was able to open it back in June when I got Verizon FiOS, but with a new router(Same Kind: MI424-WR Rev. D.) I can't get it to work. I've ...
I currently have an ESXi server configured, with both NICs in the server configured as trunks. They connect to a Cisco 3750 stack. Here is my switch config: XXXXX#sh run int gi2/0/9 ...
I can log into the ASA 5505 using the WEB interface, however when I try to use the ASDM launcher I receive the following message: ASDM is unable to read the configuration from the ASA.  I am u...
Have a Linksys SRW224G4 switch that was recently flashed with an upgraded firmware program, fesm-12216.ros. After rebooting and logging in through the HTTP interface, the main thing that appea...
I just got an eMachine with a D945CGL motherboard. The system came with Vista home and promptly removed to install Windows XP Pro. Problem is that the  Intel 82562G - Ethernet, - Fast Ethernet...
Just wondering if I should be able to ping my broadcast address 192.168.21.255 Im getting replies back......Im wondering what device is actually replying.....every host on the network?
Hi guys, I have a problem - loaded new IOS image onto 3750 *.tar file. (Had to delete old IOS for this one to fit). It then came up with the error on boot saying "magic number mismatch: bad...
Hi all , I am not having  experience on CCVP or voip , but on my new job i have given the task to manage the Cisco CME 3845 router as well . This router is operating perfectly as of now . CME ...
Cisco 2811 got a 4 port ethernet module.When trying to assign IP it says (% IP address may not be configured on L2 links). tried  "no swicth port" but says not convertiable. Created a vlan 10...
Belkin Wireless Router, F5D8231AU4 N1, 300Mbps, 802.11g http://www.ascent.co.nz/productspecification.aspx?ItemID=350664 http://www.belkin.com/pressroom/bulletins/uploads/F5D8231au4.pdf I...
I have a Dell 5324 switch and I need the command to reset the switch back to nits original configuration or default factory settings. Thanks
  I am currently running 802.11G access points building-to-building with outdoor 8dbi antennas. The access points are connected to the antennas via a single RP-SMA connector. Am I SOL trying ...
suppose there is person cisco certified how can I verify this from cisco web site I have his cisco ID
Hello, I have a Cisco 7940 phone which was configured to use a SIP VOIP provider (voipfone.co.uk) and worked great for just under a year and it has suddenly stopped working. When the ph...
Experts, I have a server room thermostat placement question. Attached you will find a screen shot of a visio drawing of our new server room that will be built. Where would the best location...
Hi everyone, I have a laptop that cannot see my home wireless network even when it is sitting 1m from the router.  It also cannot see any of the neighbours wireless networks.   A second ...
Hi Is it possible to use a wirless AP or router to link another building (maybe 20m away) to our existing wireless N network. We have a Linksys WAG160N in the office with about 5 PC's ...
I use Dell DRAC's to manage all of the Dell servers I sell to my clients.  I usually set them up myself and test them.  However, I have a new client on the west coast and I'm on the east coast...
I have a situation where I set up a DynDns record to abc.dyndns.org and I need to set up a Static VPN to use this record. I cannot figure how to get the record to be used or if I even need it....
Do in need this?  It is showing in the device manager with a yellow triangle and states "This device cannot start (Code10)
I went to the MySonicwall site but it only offers me "free" downloads, after signing in. What does it take o get the latest firmware update for a TZ170? Do I need to input it's serial number...
Hello all, I am quite a bit more familiar with Cisco with regards to spanning tree. However, we have some Extreme switches running XOS 12.2 code, latest rev. I need to uplink via a trunk/tag...
Hello, I have a Cisco 1841 router that I am configuring for an MPLS line and I have locked my self out of it somehow.   I have a copy of the original time I set the password, but I mistyped it...
How can I find "open" IP addresses on our network?  (I need to create an IP address for a printer)...
