I have some workstations that have no floppy or CD drives. I am wanting to be able to use Norton Ghost to recover some of these PCs. In my head I'm thinking that the best way to do this is p...
It seems like no specify document I can find regarding migration of WFS 7.3 to WSM 8.3.
I have a WatchGuard Firebox x1000 and a software is running WFS 7.3 version, with VPN and DHCP.
We...
This is strange.
Computer running windows XP home with SP2.
MSI mother board with a built in 10/100 NIC.
Added a 2nd NIC, Dlink 10/100 flavor.
Dlink hooks up to Cable modem for intern...
Im new to wireshark - the successor of ethereal
http://wiki.wireshark.org/
How do I do a latency check between 4 pcs with this ap?
I have a sonic wall PRO 4060, I cannot find out how to change the Admin password. Can anyone help?
I have a Netgear GSM7324...
I've created a vLAN, added a few ports to it, and tried plugging in 2 computers on those ports - but they can't see each other. If, however, I include the ports...
We have a couple linkys SRW224 switches uplinked to our core switch linksys 2024 and when we ping them we get time outs and 13ms and higher ping times. Our other switches (Cisco and Linksys) ...
I could not get rww working on our 3com vpn firewall, so i cleared the check boxes for ipsec/lpt2/pptp on the vpn section and opened port 4125 on the vitual server section of the firewall and...
I have a problem. I have a 4506 Catalyst Switch with four modules. Attached to two of the modules are HP printers. These printers have ip address defined to them. When I try to ping the print...
I have a 3Com 3c509 Combo network card. Does anyone know where to get a driver for it? It is installed on a very old 400Mhz Intel computer running Windows XP. Any help appreciated.
Thank...
Is there an easy way of identifying the IP addresses of all the appliances attached to my netwok?
Thanks.
I will be networking 2 new DEll optiplex Pcs using a broadband router. It has 4 LAN ports in the back. Will I be able to connect a network printer to these 2 pcs by simply plugging in the netw...
I am installing some CAT6 and am wondering how important the CAT6 patch panels are. I inherited a CAT5 patch panel and don't have any CAT6 hardware yet. In my walls I have run CAT6 and termina...
I have been assigned a project and wanted to get your opinions on the configurations and approach. I am not sure exactly how to complete some of the specifics, but in theory, it should be fai...
I am looking at buying a used terminal server. I want to connect to some IBM xseries computers remotely.
I see a lot of the Xyplex Maxserver 1620 Terminal Servers for sale. Is there anyth...
Hi all,
Our home network consists of 2 XP SP2 boxes and 1 SBS 2003. All connect to the internet via a router hub (Billion BiPAC7300 DSL2+). All LAN connections are visible and file transfer...
I have a self-installed Windows XP Pro (SP2 + all MS updates) that keeps giving me all kinds of problems. I'm trying to determine if this his a hardware error or if I have some kind of rootkit...
How do i Block Network Neighbourhood MyNetwork Places on Windows XP Clients. When users logon they open Microsoft Word and then if they type in the server name as it shows the server name in ...
Does anyone know of a way to trace a LIVE ethernet cable without disconnecting it? (If it's even possible)
Thanks.
We recently had a Toshiba phone system installed on our network and the consultants decided to put this on a separate VLAN/subnet than the rest of our equipment. This VLAN was set up on our L...
have a cisco WS-C4510R core switch with IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(18)EW3 running. I have vlans from 1 to 18. I need to be able to do the folowi...
I have an SBS2003 std edition server that is sitting behind a BT BT2700HGV router.
The server has dual NIC
I have ( I think) configured the router for UltraVNC in the hosted applicatio...
HI
I was wondering if you Can stream High Definition (HD) content through a gigabit home network Smoothly enough without lag ???
What is the throughput of a gigabit network ???
I am running Windows 2003 Web Server Edition and when it boots to the Login screen, it does a memory dump. I can go into safe mode and it never dumps. I ran a debug and listed the output below...
