Visit Experts Exchange from your mobile device to search, ask, and monitor your questions. Never lose touch again.
Preview From Your Desktop
Time Tested Networking Hardware Solutions: 101 - 125 of 839
Does anybody know how to configure the Dell PowerConnect 3424 switch so that 3 ports, for example 15,16,17 could be members of 2 VLANS and PCs connect to those ports, DHCP clients or static IP...
We are trying to troubleshoot why a particular 7206vxr is crashing. Here is a little background...We are loading the chassis with an NPE-g1 (1gb) and (5) PA-A3-T3' After configuring and loadin...
Guys, i have just bought a new cisco 1800 series router, conencted it up to my machine. but have forgotten how to log into it via command prompt, i'm sure it was something like - con...
I have call manager 4.1 cisco 7940 phones and 7960 VOIP i dont think anyone will need anymore info I dunno if it SIP I would like to put our logo on there if it can be done. Im n...
I recently upgraded my motherboard and haven't been able to access the internet or other computers on the network since.  I've downloaded the latest driver for the network controller at Marvel...
Hi, I have been trying to set up interface failover and high availability for my Juniper SSG5.  I've downloaded the manual and have read the high availability chapter, but when I try to sta...
Trying to get VRF-LITE with BGP over a basic IP routed network, where the IP network is not aware of the IP ranges at the end nodes. Basically Site1 10.0.0.x    | Router A Site side ...
I am using a TZ-170 with the latest EnhancedOS firmware. I have a single T-1 coming into the office with a scope of 5 static IPs. What I need is to split the connection into 2 mutually exclusi...
Hi there I have a server with a dual port Intel Pro 1000 MT, and I'd like to setup an adapter team. Does anyone know which utility I should install and how I can go about setting this up? ...
Hey Guys, Thanks in advance to anyone who can respond quickly to this! I have a Linksys Wireless WRT54g Router, but during a recent move, I have accidentally "misplaced" the original power ...
I have a 3Com 4500 managed switch. During the configuration process, I managed to use most of the memory of the device. In the process, the boot file and application file have been deleted. I ...
Hello there, I have one WRT54G router in my house and internet.. I also have another WRT54G router in the shed where I work about 300 FT away from home.. right now im using the router in the...
Hello all I have a job interview tomorrow and now I find out they want to know about my cisco experience. I was working with routers for 3 ears but that was almost 4 years ago. They also...
Dear Experts i bought a management switch the Linksys SRW 2024 to isolate between its 24 ports but couldin't after many hours of work. the user guide that comes with it does not help. what...
In device manager, there is a yellow exclamation point next to "Packet Scheduler Miniport #3" under Ethernet adapters. The reason it gives is "windows cannot start this device because its conf...
I need to upgrade the IOS on a Cisco 2811 Router.  What are the steps using a usb key? Thx
Hello, I am new with cisco and have used the startup assistant to configure this firewall. i initally could not connect, so this is why you may see the 'any any' rules in an attempt to make a...
I am sharing a dsl connection with one of my friend and a cable is running from his home switch to my pc. i have another pc upstairs and dont want to run a separate cable from his home or use ...
I had a couple of questions, so after a half an hour of google inestigating, I have come to some conclusions so I need to confirm/deny my thoughts. Here they are (correct me if I am mistaken):...
hi, i have setup a VPN solution for part our corporate network: The network we connect to is not internet facing. Our VPN connects to an inside interface ( Higher security level) into an outs...
Receiving the following supervisor message : %PM_SCP-SP-6-LCP_FW_ERR_INFORM: Module 2 is experiencing the following error: QChip Port#23 Noc Payload Crc Error from a 6509 running s72033-...
It looks like I will be making some changes in my home:  switching rooms around, etc. Because of this, I will need to rerun cabling for my network.   I am considering installing a small pane...
Cisco Switch 2950-24 Connected via f0/24 to FTP server (10.20.30.40) Commands via console. #copy flash tftp #source filename []? c2950-i6q412-mz.121-22.EA2.bin Address.. 10.20.30.40 ......
Hello, I have a HP Proliant BL460c with two int NICs "NC373i multifuntion gigabit"... 1) What are the required steps in order to team them? 2) Do I have to config each NIC separetely wi...
Hello, I am trying to setup site-to-site VPN behind Verizon Business FiOS static IP Actiontec router. The secondary router is Linksys RVO16. The routers on the other end are also Linksys RV...
