I got hp pro curve 2626 switch i want to update the software.i have downloaded the software from hp procurve. so can any body explain clearly and step by step what i have to do how i can updat...
What's the difference between restricted and unrestricted license for a Cisco 515E firewall?
On the restricted license are there any limitations on the amount of ethernet interfaces it can ...
I have couple of 65xx series switches on which Network Packets were being dropped . With help of Wireshark Network Capturing tool i captured the statistics of particular vlan , port etc , of o...
Something strange is happening at the network here at work. When browsing the internet occasionally the browser will result with an "Internet Explorer cannot display the webpage" message as i...
We have a SonicWALL TZ170 (full details at end of this email), we want to be able to ...
Map multiple public IP addresses to separate private IP addresses inside our internal network...
hi,
i have setup a VPN solution for part our corporate network: The network we connect to is not internet facing. Our VPN connects to an inside interface ( Higher security level) into an outs...
I have a HP Proliant BL460c with two int NICs "NC373i multifuntion gigabit"...
1) What are the required steps in order to team them?
2) Do I have to config each NIC separetely wi...
I have a netscreen 5GT that has been reset to the factory defaults. I've set it up termporarily between two private sub net using CLI. It routes traffic from the trust to the untrust interfa...
I am trying to setup site-to-site VPN behind Verizon Business FiOS static IP Actiontec router. The secondary router is Linksys RVO16. The routers on the other end are also Linksys RV...
Cisco Switch 2950-24
Connected via f0/24 to FTP server (10.20.30.40)
Commands via console.
#copy flash tftp
#source filename []? c2950-i6q412-mz.121-22.EA2.bin
Address.. 10.20.30.40
We have a DSL connection to a Linksys Router with PPPOe enabled. There is a static routable address assigned to this line. The WAN side of the router is set for DHCP. I would like to enable po...
I am planning to restructure my corporate network. I plan to use the PowerConnect 5424 switch that we own to create 3 VLANs, each with its own subnet. The switch will be connected directly t...
What are the benefits and disadvantages of using a CAT6 network cable for a gigabit network?
Can anyone help with my understanding of the virtual fastethernet interface in the Cisco 3020 switches. I have installed two Cisco 3020's which are working independently in a HP blade server e...
I have the NAT in place and the ACL configured but still cannot allow traffic from Inside into my DMZ.
ASA Version 7.2(4)
hostname
domain-name
enable password encrypted
passwd ...
The title says it all, I upgraded the ASA image BEFORE upgrading the ASDM and now the ASDM will not launch because it does not support the ASA image file. Is there a CLI entry that can bring ...
i have one internet link conection to isp and have plan to add my internet link conection, so have 2 internet connetion with one have bandwith 128 kbs and one again 512 kbps, i am using cisc...
I'm trying to get a cisco 1760 call manager express to work with a cisco call manager server. I'm getting the error message Call Manager Application is not enabled when I try to config mgcp....
I currently have a user that is jumping on our wireless to use our internet connection. We keep the wireless open (until this weekend) because there was no tenants near us, but now that there...
I just got a Dell PowerConnect 3424/P managed switch. I would like to get in there to configure it, but have no experience with terminals.
The documentation says I need to use VT100 termin...
I need to know the steps involved in Teaming Two NIC cards Adapters for the purpose of redundancy. Please how do I go about this task.
LIZSAM
I need some help setting up the VPN on the RV016 router. My router sits behind a Cbeyond IAD. I have 5 public IP addresses however, the IAD give my router a private IP address to prevent hac...
I have a Cisco 3560G Layer 2 switch with a Standard Image that I want to put multiple Vlans on. I want to be able to access the Internet from all vlans. I am not an expert on Cisco switches so...
Hello experts
I have toshiba labtob and this definition lost
look to this picture
http://img32.imageshack.us/img32/5303/ccccx.jpg
250 points
is this how you do it? I'm a bit lost on a pix with this no nat/ident nat thing, and which way the statics go...
PIX with in/out/dmz1/dmz2/dmz3
out = internet
in = private address
dmz1 ...
