Time Tested Networking Hardware Solutions: 151 - 175 of 839
I'm trying to disable the firewall on a dsl 2wire 2700hg-d.  I'm going to install a Netgear FVS338 to handle the Firewall functions.  Anyone know how to disable the firewall or just make this ...
We just acquired a company and have just implemented a new Cisco ASA 5540 Web VPN solution.  We thought, great - we'll give these new 100 users SSL VPN (layer 3) and then have an ACL to limit ...
I have a Cisco Catalyst 2924 switch with computers connected to it on our network. How can we restict network access to any 'guest / unauthorised'' PC's which may connect to our network. We wa...
I need a way to be notified when syslog messages related to IDS occur in my Cisco ASA firewall.  I do not have and can't afford an advanced inspection module.  My research says that syslog ID'...
How do you reset a Cisco 2950 switch to it's defaults without a password , switch was in storage for awhile and password has been forgotten . Thanks for your help !
I am attempting to setup a new vlan on a Cisco Catalyst 4506 switch. I am hope to be able to use 3 ports on  this switch for the following. Outside Internet Router >>(Port37)>> Switch-4506...
Hi there, I'd like to know how to setup port forwarding in the following situation: I have a external router with an ip of 192.168.200.254 and 2 NIC's on my SBS server. WAN IP: 192.16...
I have a new Cisco 3750 switch with several things plugged into it and active, and the mac-address-table is not showing anything but this: Vlan    Mac Address       Type        Ports ---- ...
 I have a Juniper SSG-140 and I seem to be having a routing issue.  I am not very familiar with the management of the firewall, and only minimally familiar with networking.  I have a system o...
I wanted to know the differences between these cisco IOS:  IOS XE, XR, and IOS
I need some help setting up a management card on an APC networked battery. Basically my situation is that I use the PowerChute Network to shutdown the servers in the case that the servers go o...
Hi, I have create d two vlan , but when i see sh ip int brief , it shows VLAN methos as manual for one vlan and NVRAM method for other VLAN.. And PC connected in VLAN undwe method menual...
OK, imagine someone who doesn't know _nothing_ about CISCO equipment and how to configure CISCO and you must help him :) I have one Catalyst 2950 switch on my desk and now is time to play with...
I upgraded my PIX 515E ver 6.3(4) to Ver 7.2(1) then the PIX keeps on booting in a loop. I hit ESC to get to Monitor mode to reload ver 6.3(4): monitor> address 192.168.1.1 monitor> server ...
I'll start with what I'm trying to accomplish.  I have two tunnels on a router connecting back to two separate routers at my central location across two separate internet ISPs via a DMVPN.  Bo...
I had been looking for something like an Emulator (not simulator) for Cisco IOS. I will have a real IOS image which I can load up into an emulator and work on as if I am on the real Cisco hard...
I have a cisco 3560 POE switch with no flash on it. I deleted it to make way for a new one and lost connection. What is the quickest way to upload a new one?
Hey All,    I'm looking for a little help on choosing a load balancer. Right now I have quotes for a Radware Link Proof and a F5 Link controller. The F5 is more expensive but from what I've...
Are there several models of the Catalyst 4948 ?   I'll need a 48 port gigabit Cisco switch that a) provide Layer 3 support (so that I can define ACLs to filter traffic between     our D...
I have an unused 3com 3824 3C17400 switch that needs to be reset to default settings before being used.  Before I am able to do this I am prompted for a password.  The password I had been prov...
I'm having trouble connecting my HP laser printer to my network.  I don't seem to be able to give it the IP address it wants.  Can someone help?
Here is the setup: I have a Netgear FVS328 in the main office.  I have had vpn capability setup with that office for quite some time from multiple computers using netgear's Prosave VPN client...
Greetings all - I've just got in some new HP demo equipment and noticed that for some reason, all of the iLO (Integrated Lights Out) cards on a specific subnet respond to pings to the broad...
I have a USB external hard drive that I would like to connect to my home Network. I have a Linksys wireless router with 4 ports. How can I connect either with and adapter or wirelessly my exte...
Hi: I'm looking for a Laser/Optical Bridge to extend my 10/100 Ethernet LAN to a building about 30 meters away.  I remember when I was working in the LAN business in the early 90's that there...
